hi
In usb section the recommended USB EMI common mode coke is ACM2012D-900-2P.The cutoff frequency for this feed through is mentioned as 3.5GHZ from the datasheet but the third harmonic frequency of the USB 3.0 Signalling will be arround 7.5 GHZ will this part be ok or we need to go a head with parts having similar spec with higher cut off band
