USB connection issue between Jetson Xavier NX and iPad Air 5
Hi.
I have a issue regarding the USB connection between iPad Air 5 and Jetson Xavier NX.
If I manually connect iPad Air 5 to Jetson’s USB 0 port, iPad will recognize Jetson. I think this is correct.
  • A USB type C cable is used for this connection.
  • When connecting iPad to Jetson, iPad acts the host and Jetson acts the device.
However, if I turn off / on Jetson with the USB cable connected, the iPad will not recognize the Jetson and will never recover.
For the iPad to recognize the Jetson, I need to unplug and plug the USB cable again manually. I’m in trouble!
How do I resolve this issue?
I’m guessing that Jetson is probably acting as the USB host in booting process and some issues are occurred when Jetson change to USB device.
Can I fix the Jetson’s USB setting to device in all booting process?
Of course, If you know the other way to resolve this issue, it is OK. Please tell me.
Best Regards.
Correct.
Hi.
Thanks for reply.
So, How can I resolve this issue?
Can I reconnect the USB after occurring this issue?
Best Regards.
Only can do this way, due to Mac OS compatible issue.
