# USB controller driver bug/issue in default rootfs and kernel customization - Jetpack 6.1 L4T 36.4.3
**URL:** <https://forums.developer.nvidia.com/t/usb-controller-driver-bug-issue-in-default-rootfs-and-kernel-customization-jetpack-6-1-l4t-36-4-3/358794>\
**Category:** Jetson Orin NX\
**Tags:** usb\
**Created:** [January 27, 2026, 7:23am UTC](https://forums.developer.nvidia.com/t/usb-controller-driver-bug-issue-in-default-rootfs-and-kernel-customization-jetpack-6-1-l4t-36-4-3/358794 "2026-01-27T07:23:49Z")\
**Posts on this page:** 1\
**Showing post:** 38
<div class="post-metadata">
**Author:** ![DaneLLL](https://sea2.discourse-cdn.com/nvidia/user_avatar/forums.developer.nvidia.com/danelll/32/14043_2.png) [@DaneLLL](https://forums.developer.nvidia.com/u/DaneLLL)\
**Post date:** [February 6, 2026, 4:54am UTC](https://forums.developer.nvidia.com/t/usb-controller-driver-bug-issue-in-default-rootfs-and-kernel-customization-jetpack-6-1-l4t-36-4-3/358794/38 "2026-02-06T04:54:11Z")
</div>
You should be missing some steps in
[Kernel Customization — NVIDIA Jetson Linux Developer Guide 1 documentation](https://docs.nvidia.com/jetson/archives/r36.4/DeveloperGuide/SD/Kernel/KernelCustomization.html#building-the-nvidia-out-of-tree-modules)
After the step:
> 1. Run the following commands to install:
> ```auto
> $ export INSTALL_MOD_PATH=<install-path>/Linux_for_Tegra/rootfs/
> $ sudo -E make modules_install
The 3 files will be copied to
```auto
<install-path>/Linux_for_Tegra/rootfs/usr/lib/modules/5.15.148-tegra/updates/
_[View the full topic](https://forums.developer.nvidia.com/t/usb-controller-driver-bug-issue-in-default-rootfs-and-kernel-customization-jetpack-6-1-l4t-36-4-3/358794)._
