Is there a way to monitor the current drawn from USB ports. I know the ‘Bus Max power’ option form lsusb gives the current required by the device but its not the actual current drawn.
If the power monitor section does not mention this, then it is not supported.
hey @WayneWWW ,
thanks for the reply .I couldn’t find anything specifically for USB ports. the voltage rails mentioned in the document you shared SYS5V does this include USB or any of the other 5?
