USB Device Frequency Setting Error on NVIDIA DRIVE ORIN
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
Hello, I have recently flashed our device with the latest available OS (i.e. 6.0.10.0-36101120). Before flashing we didn’t have any issues with our USB audio device. Our device includes both input/output lines. However, now, with the new OS, the system fails to set the frequency, resulting in the following error messages:
Error String
[  357.503785] usb 1-3.1: 1:1: cannot set freq 48000 to ep 0x3
[  357.531805] usb 1-3.1: 2:1: cannot set freq 16000 to ep 0x83
Log 1
dmesg output:
nvidia@tegra-ubuntu:~$ sudo dmesg | grep -i 'usb' | grep '1-3'
[    2.728118] usb 1-3: new high-speed USB device number 3 using tegra-xusb
[    2.896321] hub 1-3:1.0: USB hub found
[    3.280116] usb 1-3.4: new low-speed USB device number 5 using tegra-xusb
[    3.404644] input: Dell Dell Wired Multimedia Keyboard as /devices/platform/3610000.xhci/usb1/1-3/1-3.4/1-3.4:1.0/0003:413C:2110.0002/input/input2
[    3.476763] input: Dell Dell Wired Multimedia Keyboard Mouse as /devices/platform/3610000.xhci/usb1/1-3/1-3.4/1-3.4:1.1/0003:413C:2110.0003/input/input3
[    3.476873] input: Dell Dell Wired Multimedia Keyboard System Control as /devices/platform/3610000.xhci/usb1/1-3/1-3.4/1-3.4:1.1/0003:413C:2110.0003/input/input4
[    3.536225] input: Dell Dell Wired Multimedia Keyboard Consumer Control as /devices/platform/3610000.xhci/usb1/1-3/1-3.4/1-3.4:1.1/0003:413C:2110.0003/input/input5
[  346.734750] usb 1-3: USB disconnect, device number 3
[  346.734759] usb 1-3.4: USB disconnect, device number 5
[  354.479850] usb 1-3: new full-speed USB device number 6 using tegra-xusb
[  354.634372] hub 1-3:1.0: USB hub found
[  357.339798] usb 1-3.1: new full-speed USB device number 7 using tegra-xusb
Log 2
aplay -l output:
nvidia@tegra-ubuntu:/proc/asound$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: SafetyI2Ssoun [], device 0: i2s7 []
 Subdevices: 1/1
 Subdevice #0: subdevice #0
card 1: tegravirtpcmvm1 [tegra-virt-pcm-vm1], device 0: playback ADMAIF1 CIF-0 []
 Subdevices: 1/1
card 1: tegravirtpcmvm1 [tegra-virt-pcm-vm1], device 1: playback ADMAIF2 CIF-1 []
 Subdevices: 1/1
card 1: tegravirtpcmvm1 [tegra-virt-pcm-vm1], device 2: playback ADMAIF3 CIF-2 []
 Subdevices: 1/1
card 1: tegravirtpcmvm1 [tegra-virt-pcm-vm1], device 3: playback ADMAIF4 CIF-3 []
 Subdevices: 1/1
card 2: P20M [Poly Sync 20-M], device 0: USB Audio [USB Audio]
 Subdevices: 1/1
Log 3
lsusb output:
Bus 002 Device 002: ID 04e8:4001 Samsung Electronics Co., Ltd PSSD T7
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 014: ID 413c:301a Dell Computer Corp. Dell MS116 USB Optical Mouse
Bus 001 Device 023: ID 047f:015d Plantronics, Inc.
Bus 001 Device 022: ID 0a12:4010 Cambridge Silicon Radio, Ltd
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Please advise us on how to get our device to work again.
What was the DRIVE OS version previously on target? Was your USB audio device working Out of the box earlier or you need to use settings/commands to bring it up?
It used to be 6.0.4.0-31006010 with Linux kernel 5.10.104.
Yes, my USB audio device was working perfectly out of the box. I didn’t need to use any additional settings or commands to get it up and running
Dear @bahareh.bafandehmayvan,
Audio/bluetooth/Wifi is not officially supported on DRIVE OS devzone releases. Please use old release in case you have audio as critical requirement.
Is it working on DRIVE OS 6.0.6 and DRIVE OS 6.0.8.1 releases. can you verify and provide feedback?
also, please provide the above similar logs for 6.0.4/6.0.6/6.0.8.1 as well?
Dear @bahareh.bafandehmayvan ,
It is looking related to kernel upgrade in sound/usb (from k5.10 → k5.15 ) . Noticed similar error reported at https://lore.kernel.org/lkml/87pm6aicin.wl-tiwai@suse.de/T/
some vendor audio chip appeared stop working.
Can you try with different vendors?
Hello @SivaRamaKrishnaNV ,
Thanks for the follow-up. At this time, it is not possible for us to use other vendors. However, we have found a workaround to unblock ourselves:
To play an audio file, we used the following command (Note: the audio sample rate should be 16k):
aplay -vvv -D plughw:2,0 --period-size=512 /path/to/audio.wav
To record audio, we used this command:
arecord -vvv -D plughw:2,0 --period-size=512 /path/to/recorded.wav
