USB devices not working
Im using an Orin Nx with a Aver Media D131 Carrier Board board ive installed jetpack 6.2 sucessfully , but the only way i can do anything on it is via ssh , no peripherals are being detected
Are There any exrtra drivers that i need to install for proper usb support ?
You cannot just get a custom carrier board and flash it with sdkmanager. You should contact board vendor if they have their own customized BSP to flash their board.
Sdkmanager only supports Devkit.
Had no clue about this , thanks for the info , it works perfectly now .
