USB devices removed automatically in jetson nano
I have connected the following usb devices to jetson nano
a usb sdcard reader with highspeed sdcard
two usb cameras
a usb hub
I am using a gstreamer pipeline to encode the 2 usb camera feeds and save it to the sd card. The issue ecountered is ,all the usb devices get detached after a while(while running the gstreamer pipeline) and are not detected even after replug. The usb devices will be detected only after a powerdown or reboot.
I am also doing the same encoding with single usb camera and a network camera. There is no issue in this scenario.
What can be the problem for the usb detaching when 2 usb cameras are encoded?
Thanks in advanced
There is a significant likelihood that the issue is caused by power draw (cameras tend to pull a lot). Can you try a powered USB HUB? Switching power drain away from the Jetson might fix this.
the usb hub used is externally powered will update by considering the power
