I am trying to understand the cause of damage to my Jetson Orin Nano Super Developer Kit and would appreciate any guidance regarding further debugging and possible repair.
Device
Component Damaged
The ESD protection IC (marked 561SY) of the third USB port appears to have burned out. After failure, the port developed a short circuit between the USB data line and ground.
Connected Peripherals
- USB Port 4: Intel RealSense D455 camera
- USB Port 2: Keyboard and mouse receiver dongle
- USB Port 1: 5-inch HDMI display (powered through USB)
Power Source
The board was powered using a 6S LiPo battery connected to an LM2596 buck converter, supplying a stable 18.8–18.9 V output, which is within the supported operating range (9 V to 19 V) of the board.
Peripheral power consumption:
- 5-inch display: ~0.5–0.6 W
- Intel RealSense D455 camera: ~0.5–0.6 W
Incident
The issue occurred after plugging the display power cable into USB Port 1. This appears to have resulted in the burnout of the USB ESD protection IC (561SY).
Debugging Performed
To isolate the issue, the following checks were completed:
- Verified the power supply output, which remained stable at 18.8 V.
- Checked the USB power and data lines of both the camera and display for abnormalities.
- Tested the display and RealSense camera independently on another device, where both operated normally with stable power consumption.
Questions
- What could be the most likely root cause of the ESD IC failure in this situation?
- Could the LM2596 buck converter or startup voltage transients/spikes have contributed, even though the measured voltage remained stable?
- Is it possible that the display’s USB power cable introduced a fault condition (backfeeding, short, incorrect wiring, or surge) onto the USB line?
- What further debugging steps would you recommend to determine whether the issue is isolated to the ESD IC or if additional USB circuitry may also be damaged? For example:
- Checking USB rail voltages
- Measuring continuity/resistance on D+/D− lines to ground
- Inspecting nearby components or USB controller paths
- If the fault is limited to the ESD protection IC, would replacing the 561SY IC typically restore functionality, or are there other components that should also be checked/replaced?
Any insights into the probable root cause, additional diagnostics, or repair recommendations would be greatly appreciated.
