For reference I found this here (they have a support email address, but you probably won’t need it…still, it is there):
https://www.trellisware.com/trellisware-radios/tw-875-tsm-ghost/
Fascinating device. To test for the CDC_EEM driver on the Jetson:
zcat /proc/config.gz | grep -i 'cdc_eem'
You might still need a udev
file like “/etc/udev/rules.d/99-com.rules
” (I don’t know for sure if that is for your device, but if you attach a copy to the forums, then we can find out…you might need to rename it with a .txt
suffix).
The CDC_EEM
is a standard driver, but you might need to build it as a module (which install is then just a file copy…ignore docs which want you to flash since you are not installing a new kernel and are just adding a module).
The docs associated with your specific L4T release have the official information in the “kernel customization” section, see the docs for your release:
https://developer.nvidia.com/linux-tegra
(to find the L4T release use “head -n 1 /etc/nv_tegra_release
If the official docs are not enough, here is some extra info on kernel build:
https://forums.developer.nvidia.com/t/topic/193640/11
If your system does not have that already, although the docs are extensive, it is much easier than it sounds for a module install.
