Usb iso flash with custom carrier board
Im looking on advice on how I could add the custom carrier board files to the iso image that is used to flash the newer JP 7.2
Thanks for reaching out! To help you integrate custom carrier board files into your JP 7.2 ISO image, I need a bit more context:
  1. Which carrier board are you using? (e.g., custom third-party board, NVIDIA devkit variant, etc.)
  2. What specific files need to be added? (e.g., device tree overlays, firmware, kernel modules, bootloader files)
  3. Have you attempted any integration methods already? If so, what was the result?
  4. Are you looking to create a custom ISO from scratch or modify an existing JP 7.2 ISO?
  5. What is your target hardware platform? (e.g., Jetson Orin, Orin NX, Orin Nano, Xavier, etc.)
Once I understand your specific setup and goals, I can point you to the right approach—whether that’s modifying the L4T build system, using flash scripts, or post-install integration.
  1. forecr DSBoard-agx Jetson AGX Orin Carrier Board - DSBOARD-AGX | Forecr 2.
  2. they have custom bsp dsboard_agx_orin_bsp/dsboard_agx_agx_orin_JP7_2_bsp.tar.xz at master · forecr/dsboard_agx_orin_bsp · GitHub
  3. I have not attempted it yet
  4. Im looking to add to the original iso from the sdk manager but open if there is a custom way to create one
  5. target is jetson orin agx
You could look at
https://forums.developer.nvidia.com/t/create-a-jetpack-7-2-live-iso-for-thor-or-orin-similar-to-ubuntu-live-cd/373964/1
And look at the md5sum parts to make it bootable. with new files/sizes.
how would i go about adding the bsp image to the iso ?
The iso that you can create with build-ORIN-live-iso.sh contains the entire Jetpack 7.2 installation iso. Put jetsoninstaller-r39.2.0-2026-06-01-23-53-13-arm64.iso in the same directory as the build script. Run build-ORIN-live-iso.sh to get the base for this process of about about 18gb.
You would need to look at build-ORIN-live-iso.sh and copy parts required to install your exact changes into the ./build-orin/chroot. Then copy the parts of build-ORIN-live-iso.sh that run md5sum and builds the iso.
