USB issue: Set TR Deq Ptr cmd failed due to incorrect slot or ep state and arm smmu 8000000 iommu issue
Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
[y] other
Target Operating System
[y] Linux
QNX
other
Hardware Platform
[y] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
1.9.2.10884
[y] other
Host Machine Version
[y] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
log:
[ 26.338000] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[ 29.928873] wlan0: authenticate with 22:bc:5a:0a:b0:a8
[ 29.932109] wlan0: send auth to 22:bc:5a:0a:b0:a8 (try 1/3)
[ 30.061046] wlan0: send auth to 22:bc:5a:0a:b0:a8 (try 2/3)
[ 30.165032] wlan0: send auth to 22:bc:5a:0a:b0:a8 (try 3/3)
[ 30.170819] wlan0: authenticated
[ 30.173058] wlan0: associate with 22:bc:5a:0a:b0:a8 (try 1/3)
[ 30.177931] wlan0: RX AssocResp from 22:bc:5a:0a:b0:a8 (capab=0x511 status=0 aid=3)
[ 30.180468] wlan0: associated
[ 30.231229] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 30.455221] wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 22:bc:5a:0a:b0:a8
[ 30.762461] IPv6: wlan0: IPv6 duplicate address fe80::b6a1:7cfe:fc0c:e84c used by 34:13:e8:b1:31:63 detected!
[ 31.796424] IPv6: wlan0: IPv6 duplicate address fe80::b6a1:7cfe:fc0c:e84c used by 34:13:e8:b1:31:63 detected!
[ 41.585383] usb 1-3: new high-speed USB device number 5 using tegra-xusb
[ 41.738009] usb 1-3: config 1 interface 5 altsetting 1 has 2 endpoint descriptors, different from the interface descriptor’s value: 3
[ 41.752708] usb 1-3: New USB device found, idVendor=3466, idProduct=3301, bcdDevice= 1.02
[ 41.752717] usb 1-3: New USB device strings: Mfr=12, Product=13, SerialNumber=0
[ 41.752723] usb 1-3: Product: TDTECH MT571X
[ 41.752727] usb 1-3: Manufacturer: TD tech Ltd.
[ 41.777023] option 1-3:1.0: GSM modem (1-port) converter detected
[ 41.777140] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB4
[ 41.784566] option 1-3:1.1: GSM modem (1-port) converter detected
[ 41.784707] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB5
[ 41.787668] option 1-3:1.2: GSM modem (1-port) converter detected
[ 41.787790] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB6
[ 41.790147] option 1-3:1.3: GSM modem (1-port) converter detected
[ 41.790272] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB7
[ 41.852875] cdc_ncm 1-3:1.4: MAC-Address: 0c:5b:8f:27:9a:64
[ 41.865500] cdc_ncm 1-3:1.4 eth0: register ‘cdc_ncm’ at usb-3610000.xhci-3, CDC NCM, 0c:5b:8f:27:9a:64
[ 41.919807] usbcore: registered new interface driver cdc_wdm
[ 41.921421] usbcore: registered new interface driver cdc_mbim
[ 43.453511] tegra-xusb 3610000.xhci: WARN Set TR Deq Ptr cmd failed due to incorrect slot or ep state.
[ 44.350475] arm-smmu 8000000.iommu: Unhandled context fault: fsr=0x402, iova=0x7fffeb8000, fsynr=0x440013, cbfrsynra=0x100e, cb=0
[ 44.367836] mc-err: unknown mcerr fault, int_status=0x00000000, ch_int_status=0x00000000, hubc_int_status=0x00000000 sbs_int_status=0x00000000, hub_int_status=0x00000000
[ 46.569179] vdd-12v-sys: disabling
[ 46.569227] vdd-3v3-ftdi: disabling
[ 46.569245] vdd-3v3-sd: disabling
[ 52.527326] tegra-xusb 3610000.xhci: WARN Set TR Deq Ptr cmd failed due to incorrect slot or ep state.
dmesg.txt (73.2 KB)
This forum is exclusively for developers who are part of the NVIDIA DRIVE™ AGX SDK Developer Program. To post in the forum, please use an account associated with your corporate or university email address. This helps us ensure that the forum remains a platform for verified members of the developer program. Thanks.
ok Thanks.
