log:
[ 26.338000] pwm-tegra-tachometer 39c0000.tachometer: Tachometer Overflow is detected
[ 29.928873] wlan0: authenticate with 22:bc:5a:0a:b0:a8
[ 29.932109] wlan0: send auth to 22:bc:5a:0a:b0:a8 (try 1/3)
[ 30.061046] wlan0: send auth to 22:bc:5a:0a:b0:a8 (try 2/3)
[ 30.165032] wlan0: send auth to 22:bc:5a:0a:b0:a8 (try 3/3)
[ 30.170819] wlan0: authenticated
[ 30.173058] wlan0: associate with 22:bc:5a:0a:b0:a8 (try 1/3)
[ 30.177931] wlan0: RX AssocResp from 22:bc:5a:0a:b0:a8 (capab=0x511 status=0 aid=3)
[ 30.180468] wlan0: associated
[ 30.231229] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 30.455221] wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 22:bc:5a:0a:b0:a8
[ 30.762461] IPv6: wlan0: IPv6 duplicate address fe80::b6a1:7cfe:fc0c:e84c used by 34:13:e8:b1:31:63 detected!
[ 31.796424] IPv6: wlan0: IPv6 duplicate address fe80::b6a1:7cfe:fc0c:e84c used by 34:13:e8:b1:31:63 detected!
[ 41.585383] usb 1-3: new high-speed USB device number 5 using tegra-xusb
[ 41.738009] usb 1-3: config 1 interface 5 altsetting 1 has 2 endpoint descriptors, different from the interface descriptor’s value: 3
[ 41.752708] usb 1-3: New USB device found, idVendor=3466, idProduct=3301, bcdDevice= 1.02
[ 41.752717] usb 1-3: New USB device strings: Mfr=12, Product=13, SerialNumber=0
[ 41.752723] usb 1-3: Product: TDTECH MT571X
[ 41.752727] usb 1-3: Manufacturer: TD tech Ltd.
[ 41.777023] option 1-3:1.0: GSM modem (1-port) converter detected
[ 41.777140] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB4
[ 41.784566] option 1-3:1.1: GSM modem (1-port) converter detected
[ 41.784707] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB5
[ 41.787668] option 1-3:1.2: GSM modem (1-port) converter detected
[ 41.787790] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB6
[ 41.790147] option 1-3:1.3: GSM modem (1-port) converter detected
[ 41.790272] usb 1-3: GSM modem (1-port) converter now attached to ttyUSB7
[ 41.852875] cdc_ncm 1-3:1.4: MAC-Address: 0c:5b:8f:27:9a:64
[ 41.865500] cdc_ncm 1-3:1.4 eth0: register ‘cdc_ncm’ at usb-3610000.xhci-3, CDC NCM, 0c:5b:8f:27:9a:64
[ 41.919807] usbcore: registered new interface driver cdc_wdm
[ 41.921421] usbcore: registered new interface driver cdc_mbim
[ 43.453511] tegra-xusb 3610000.xhci: WARN Set TR Deq Ptr cmd failed due to incorrect slot or ep state.
[ 44.350475] arm-smmu 8000000.iommu: Unhandled context fault: fsr=0x402, iova=0x7fffeb8000, fsynr=0x440013, cbfrsynra=0x100e, cb=0
[ 44.367836] mc-err: unknown mcerr fault, int_status=0x00000000, ch_int_status=0x00000000, hubc_int_status=0x00000000 sbs_int_status=0x00000000, hub_int_status=0x00000000
[ 46.569179] vdd-12v-sys: disabling
[ 46.569227] vdd-3v3-ftdi: disabling
[ 46.569245] vdd-3v3-sd: disabling
[ 52.527326] tegra-xusb 3610000.xhci: WARN Set TR Deq Ptr cmd failed due to incorrect slot or ep state.
dmesg.txt (73.2 KB)
麻煩提供基本資訊先
NV devkit or custom board
Jetpack版本
如果不是nv devkit,有沒有辦法在devkit上複製問題
1.我们自己做的板子,用的nvidia模组
2.Jetson_Linux_R35.2.1_aarch64
我们把USB:USB2_DN USB2_DP 这个USB连接到了MINIPCIE接口上。当我把minipcie接口的外设插上之后,就会出现该问题。
外设是“ TDTECH MT571X”
請問有沒有辦法用類似的裝置在nv devkit上複製
你的意思是在英韦达的开发板上复现该问题吗?
是的 基本上所有問題我們都希望能在devkit開發版上先複製出來我們才比較容易後續確認
不是每個issue都看幾行log就能知道問題在哪的
英韦达板子没有MINIPCIE接口。暂时不能在英韦达开发板上复现该问题。
arm-smmu 8000000.iommu这个是DMA用的,会和我的硬件设计有关吗 ?
还请您在帮忙看看该问题。 谢了!
