I have a bunch of jetson TK1s that I’d like to flash and use, but I’m not able to get access to recovery mode. They all behave the same.
My monitors never detect a signal.
I’ve got a null modem attached and can see it cycle trying to boot from pxe (previous owners) and drop into local mode, but it doesn’t appear to be a full OS.
Tegra124 (Jetson TK1) # version
U-Boot 2014.10-rc2-g3127911 (Jun 07 2016 - 21:00:01)
arm-cortex_a9-linux-gnueabi-gcc (crosstool-NG hg_unknown@20110628.165246) 4.5.3
GNU ld (crosstool-NG hg_unknown@20110628.165246) 2.20.1.20100303
It seems like there is a ubuntu OS installed, I can poke around in ls, but not quite sure how to make it boot out of this barebones env otherwise.
Tegra124 (Jetson TK1) # ls mmc 0:1
<DIR> 4096 .
<DIR> 4096 ..
<DIR> 16384 lost+found
<DIR> 4096 boot
<DIR> 4096 bin
<DIR> 4096 dev
<DIR> 12288 etc
<DIR> 4096 home
<DIR> 4096 lib
<DIR> 4096 media
<DIR> 4096 mnt
<DIR> 4096 opt
<DIR> 4096 proc
62 README.txt
<DIR> 4096 root
<DIR> 4096 run
<DIR> 12288 sbin
<DIR> 4096 srv
<DIR> 4096 sys
<DIR> 4096 tmp
<DIR> 4096 usr
<DIR> 4096 var
Whenever I use the physical keys or use 'enterrcm` to go into recovery mode, I no longer get feedback from the null modem cable nor do I ever see the 0955:7410 usb device show up in my ubuntu 20.04 host.
It’s possible that they are all defunct boards, but I have a mess of them and I would have expected that at some of them were still functional.
Is it expected that the data on null modem cable will go blank when in recovery?
Is it possible that there is some sort of “touch key to continue” button not displaying because my HDMI is not showing anything?
Are there any methods of getting around recovery mode being unavailable? Perhaps in this barebones OS?
Here is the help menu from the OS for helping me identify what it is? (what’s it called?)
Tegra124 (Jetson TK1) # ?
? - alias for 'help'
base - print or set address offset
bdinfo - print Board Info structure
boot - boot default, i.e., run 'bootcmd'
bootd - boot default, i.e., run 'bootcmd'
bootelf - Boot from an ELF image in memory
bootm - boot application image from memory
bootp - boot image via network using BOOTP/TFTP protocol
bootvx - Boot vxWorks from an ELF image
bootz - boot Linux zImage image from memory
cmp - memory compare
coninfo - print console devices and information
cp - memory copy
crc32 - checksum calculation
dfu - Device Firmware Upgrade
dhcp - boot image via network using DHCP/TFTP protocol
dm - Driver model low level access
echo - echo args to console
editenv - edit environment variable
enterrcm- reset Tegra and enter USB Recovery Mode
env - environment handling commands
exit - exit script
ext2load- load binary file from a Ext2 filesystem
ext2ls - list files in a directory (default /)
ext4load- load binary file from a Ext4 filesystem
ext4ls - list files in a directory (default /)
ext4size- determine a file's size
false - do nothing, unsuccessfully
fatinfo - print information about filesystem
fatload - load binary file from a dos filesystem
fatls - list files in a directory (default /)
fatsize - determine a file's size
fdt - flattened device tree utility commands
go - start application at address 'addr'
gpio - query and control gpio pins
help - print command description/usage
i2c - I2C sub-system
imxtract- extract a part of a multi-image
itest - return true/false on integer compare
load - load binary file from a filesystem
loadb - load binary file over serial line (kermit mode)
loads - load S-Record file over serial line
loadx - load binary file over serial line (xmodem mode)
loady - load binary file over serial line (ymodem mode)
loop - infinite loop on address range
md - memory display
mii - MII utility commands
mm - memory modify (auto-incrementing address)
mmc - MMC sub system
mmcinfo - display MMC info
mw - memory write (fill)
nm - memory modify (constant address)
part - disk partition related commands
pci - list and access PCI Configuration Space
ping - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
pxe - commands to get and boot from pxe files
reset - Perform RESET of the CPU
run - run commands in an environment variable
saveenv - save environment variables to persistent storage
setenv - set environment variables
sf - SPI flash sub-system
showvar - print local hushshell variables
sleep - delay execution for some time
source - run script from memory
sspi - SPI utility command
sysboot - command to get and boot from syslinux files
test - minimal test like /bin/sh
tftpboot- boot image via network using TFTP protocol
true - do nothing, successfully
ums - Use the UMS [User Mass Storage]
usb - USB sub-system
usbboot - boot from USB device
version - print monitor, compiler and linker version
