USB port C not working
I have jetson nano orin and I want to install the jetpack using SDK manager by WSL, suddenly the USB port C is not working. I already try to change the cables but still no detect from the port C. How to check either it’s broken or is there any solution for this.
Thank you
Just run
sudo apt updates
sudo apt nvidia-jetpack
on your device.
SDK Manager on WSL does not installing JetPack SDK.
I want to flash the jetpack 5.1.3 to the orin with sd card. I need to use SDK manager to flash the jetpack or is there other way to flash it?
Thank you
Are you talking about JetPack SDK or L4T OS itself?
If you just need JetPack SDK, follow what I said earlier.
If you need L4T OS, check this:
