I did flashing for Jetson TX2 (with Orbitty Carrier) with JetPack 3.3. I was able to flash the Jetson. After that, when i connect the Jetson with monitor, Ubuntbu 16.04 was installed. However, the usb port for the carrier is not configured. I tried to connect different keyboards and mousses and still i can’t access the Jetson. I tried to use different carrier and the same thing occurs. I also tried to use Jetpack 4.2.1 with no different changes. Any advice.
Regards,
Dear 20190687,
I am moving your topic to Jetson to get support.
Duplicate of:
https://devtalk.nvidia.com/default/topic/1066379/usb-port-is-not-configured-in-jetson-tx2/
(see the above URL)
