This is expected; the Hypervisor setup for 5.0.13.2/DRIVE Software 8.0 was 8.0 shared cores across all the VMs, where 5.1.0.2/DRIVE Software 9.0 and later have 6 dedicated cores for the guest OS, and the remaining two shared for the non-guest VMs. This is to give more predictable performance to the guest VM by eliminating any interference from the Foundation Service VMs.
This doesn’t seem to be well documented anywhere unfortunately; best picture from the docs to explain against is below.
Could you help to check on hostPC if DriveAGX USB ports are available or not using lsusb command like below? Thanks.
$ lsusb
Bus 002 Device 002: ID 8087:8000 Intel Corp.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:8008 Intel Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 043: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 003 Device 042: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 003 Device 041: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 003 Device 040: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Bus 003 Device 039: ID 0424:2807 Standard Microsystems Corp.
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I did lsusb on host pc. I get the following output. I can see one port 8087:0a2b Intel Corp.
$lsusb
Bus 009 Device 034: ID 0403:6011 Future Technology Devices International, Ltd FT 4232H Quad HS USB-UART/FIFO IC
Bus 009 Device 033: ID 0403:6011 Future Technology Devices International, Ltd FT 4232H Quad HS USB-UART/FIFO IC
Bus 009 Device 032: ID 0403:6011 Future Technology Devices International, Ltd FT 4232H Quad HS USB-UART/FIFO IC
Bus 009 Device 031: ID 0403:6011 Future Technology Devices International, Ltd FT 4232H Quad HS USB-UART/FIFO IC
Bus 009 Device 030: ID 0424:2807 Standard Microsystems Corp.
Bus 009 Device 024: ID 04f2:0833 Chicony Electronics Co., Ltd
Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 010 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 8087:0a2b Intel Corp.
