USB Power Control
Please check [Kernel Customization] in Documentation
My fan doesn’t turn. I don’t know what’s wrong.is tx2 have Overheat protection
My fan turns on when it starts, and then it doesn’t turn. This problem occurred in the newly installed system.jetpack 3.3im use tx2 with J120and installed J120 drive of 1.6。
what’s the problem of tx2‘s fan
The fan does not normally run. Unless the system produces enough heat it never kicks in (you might see a very slight flicker at the moment of power on). On the other hand, the J120 would require a different device tree, and if that isn’t correct, then the fan would not work. Unlike a desktop PC this wouldn’t be instant death, but it would end up overheating at some point during a heavy workload.
What do you see from:
sudo cat /sys/kernel/debug/tegra_fan/target_pwm
A “0” is auto speed control. This would force the fan to max:
sudo echo 255 > /sys/kernel/debug/tegra_fan/target_pwm
This would put the fan back into auto mode:
sudo echo 0 > /sys/kernel/debug/tegra_fan/target_pwm
If the device tree is not in, then either the files won’t exist or won’t do as expected.
