I have a Jetson Nano and want to use it with an Arducam Cammarray with four imx219 sensors. Now my problem is, that the Camarray needs an external powersupply via USB (as far, as I know, its also possible via GPIOs, but I don’t know, if that works with Jetson Nano too). Because I only have a 5V (it’s sometimes a bit higher or lower, because when booting, the JN needs more power) source, that is delivered by a battery, I can’t just use another plug. So I want to power it with one of the USB-connectors of the JN, but then I just get an error:
with "gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080,format=(string)NV12, framerate=(fraction)29/1’ ! nvoverlaysink
" I get:
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:740 No cameras available
Got EOS from element "pipeline0".
Execution ended after 0:00:00.001296989
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
When I run it via OpenCV in Python (thats, how I want to use it), I just get a message, that there’s no camera detected to.
I think, that the problem is, that the Cammarray gets power, after the JN booted, because with external powersupply it works, when I give the Cammarray power before the JN.
Is there a way to check again, if a camera is connected, or a different solution?
Best regards, Konrad
