USB problems caused by different formats of SD cards
The core of the xavier nx we use, the system version is Jetpack4.6, and found in use, when the SD card is in dos format, the dmesg information has been repeatedly outputting the following information:
[   42.155152] usb usb2: usb_suspend_both: status 0
[   42.310240] usb 1-3: usb_suspend_both: status 0
[   47.551667] usb usb2: usb_suspend_both: status 0
[   47.714283] usb 1-3: usb_suspend_both: status 0
[   52.923853] usb usb2: usb_suspend_both: status 0
[   53.094311] usb 1-3: usb_suspend_both: status 0
However, when the SD card is in gpt format, the above information will not be output.
When printing this information, there will be an impact on the function of the USB.
Is there any good solution?
If gpt format works, you can simply use it. Is there a strong reason to use dos format?
We can use GPT format to work normally, but our customer seems to need DOS format, may I ask what causes this problem?
