Hi,WayneWWW
I just tried and wanted to sync the latest results with you. When entering recovery mode using the hardware button, both front and back insertions show 2.0. However, when flashing the kernel initrd, one shows 2.0 and the other shows 3.0, which seems like there might be an issue with the mux. At 3.2, the flashing rate is much faster.
root@wpces:/home/wpces# lsusb
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 0e0f:0003 VMware, Inc. Virtual Mouse
Bus 003 Device 003: ID 0e0f:0002 VMware, Inc. Virtual USB Hub
Bus 003 Device 004: ID 0e0f:0002 VMware, Inc. Virtual USB Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 002: ID 0955:7100 NVIDIA Corp. Tegra Device
root@wpces:/home/wpces# lsusb -v -d 0955:7100 | grep 'bcdUSB'
bcdUSB 3.20
bcdUSB 3.20
root@wpces:/home/wpces# lsusb -t
/: Bus 001.Port 001: Dev 001, Class=root_hub, Driver=uhci_hcd/2p, 12M
/: Bus 002.Port 001: Dev 001, Class=root_hub, Driver=ehci-pci/6p, 480M
/: Bus 003.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/4p, 480M
|__ Port 001: Dev 002, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 003: Dev 003, If 0, Class=Hub, Driver=hub/7p, 12M
|__ Port 004: Dev 004, If 0, Class=Hub, Driver=hub/7p, 480M
/: Bus 004.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/4p, 10000M
|__ Port 001: Dev 002, If 0, Class=Vendor Specific Class, Driver=usbfs, 5000M
Bus 003 Device 010: ID 0955:7100 NVIDIA Corp. Tegra Device
bcdUSB 2.10
|__ Port 002: Dev 010, If 0, Class=Vendor Specific Class, Driver=usbfs, 480M
