USB Spread Spectrum Clock on Jetpack 39.2
Is there a way to enable spread spectrum clock on jetson orin nx 16GB? It currently isn’t working and we are failing USB 3.1 Gen 2 SI testing because of it. We used busybox to read the register and saw it is currently high, which means it is disabled. We tried writing to the register, but it didn’t hold the value we tried writing. I saw an older post that this was a bug in older versions of Jetpack, but it was going to be fixed.
May I confirm you command to check SSC? It sounds a bug to me.
We used “sudo busybox devmem 0x20041000”
Hi!
Could you share your exact JetPack/L4T version and the full register value? At 0x20041000, check bit 12 specifically: 0 enables SSC and 1 disables it. Also check whether the flashed BPMP DTB contains disable-spread = <1> under clock@plle, which explicitly disables SSC. These checks would help check to see whether this is a configuration issue or a possible firmware issue before attempting further register writes.
Best regards,
Fabian Munoz
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
We are using Jetson Linux version 39.2. I attached the screenshot of the command and result we ran in Linux and it is disabled. Also the BPMP DTB does not contain a clock@plle node at all so there is no disable-spread property at all.
looks like an issue. Are you using NVMe device on C4 to boot?
Yes I’m using a NVMe drive connected to C4 which is the x4 bifurcation on the Orin NX module.
Thanks for confirming. The node not being there does not mean necessarily there is an error. USB 3 and PCIe C4 both use UPHY0/HSIO, so a useful diagnostic would be to compare SSC after cold boots with and without the C4 NVMe, provided you have an alternative boot device. If you also provide the full UART boot log and the BPMP DTB used during flashing, it may be helpful.
Best regards,
Fabian Munoz
No, it is a software issue to us… we will check.
