usb swing setting
Hi NV people
how to set usb swing in the R32.1 system ?
Please share more about ‘USB swing setting’. We are not sure what the function is.
Hi DaneLLL
In usb test , many usb define differential swing spec.
and system can change the voltage swing.
in the xavier , could i modify the usb voltage swing ?
USB voltage swing should refer to D+/D- signaling voltage level, it’s around 4xx mV single end.
