I used usb wifi, causing a kernel panic,Sagem XG-76NA model will have issue; The Realtek RTL8188EU model has no issue.I use jetpack 5.1.2.
titan@zdrive:~$ [ 253.246926] kernel BUG at mm/vmalloc.c:2065!
[2023-09-06 16:06:20.724] [ 253.251353] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[2023-09-06 16:06:20.760] [ 253.257006] Modules linked in: nvidia_modeset(OE) fuse xt_multiport ip6table_filter ip6_tables xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink xt_addrtype iptable_filter iptable_nat nf_nat nf_conntrack switch mttcan nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c can_dev br_netfilter can_raw lzo_rle can lzo_compress zram overlay mv88e6xxx ramoops reed_solomon dsa_core loop camera ox03c10 imx390 nvgpu rtl8xxxu rtl8192cu rtl_usb rtl8192c_common rtlwifi aes_ce_blk snd_soc_tegra186_asrc crypto_simd snd_soc_tegra210_ope cryptd mac80211 snd_soc_tegra186_dspk snd_soc_tegra186_arad snd_soc_tegra210_iqc snd_soc_tegra210_mvc snd_soc_tegra210_afc aes_ce_cipher snd_soc_tegra210_dmic snd_soc_tegra210_adx snd_soc_tegra210_amx ghash_ce snd_soc_tegra210_admaif snd_soc_tegra210_mixer binfmt_misc spi_nor input_leds snd_soc_tegra210_i2s sha2_ce snd_soc_tegra_pcm sha256_arm64 snd_soc_tegra210_sfc sha1_ce cfg80211 pwm_fan snd_soc_tegra_machine_driver snd_soc_spdif_tx snd_soc_tegra210_adsp gw5200 ofpart
[2023-09-06 16:06:20.840] [ 253.257171] userspace_alert snd_soc_tegra_utils max96712 cmdlinepart snd_hda_codec_hdmi snd_soc_simple_card_utils max9296 max9295 snd_hda_tegra snd_hda_codec qspi_mtd nvadsp nvethernet nvidia(OE) nvmap snd_hda_core snd_soc_tegra210_ahub mtd snd_soc_sgtl5000 tegra_bpmp_thermal nct1008 tegra210_adma ina3221 spi_tegra114 max2008X spidev ip_tables x_tables
[2023-09-06 16:06:20.846] [ 253.381407] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G OE 5.10.104 #8
[2023-09-06 16:06:20.864] [ 253.389125] Hardware name: /, BIOS r35.0-7deb3d3 06/27/2023
[2023-09-06 16:06:20.864] [ 253.394971] pstate: 00400009 (nzcv daif +PAN -UAO -TCO BTYPE=–)
[2023-09-06 16:06:20.864] [ 253.401166] pc : __get_vm_area_node.isra.0+0x160/0x180
[2023-09-06 16:06:20.869] [ 253.406464] lr : __get_vm_area_node.isra.0+0x40/0x180
[2023-09-06 16:06:20.874] [ 253.411671] sp : ffff800010003510
[2023-09-06 16:06:20.877] [ 253.415090] x29: ffff800010003510 x28: 0000000000000001
[2023-09-06 16:06:20.883] [ 253.420566] x27: 0000000000000000 x26: ffffb738698d71b0
[2023-09-06 16:06:20.890] [ 253.426050] x25: fffffdffbfff0000 x24: ffff800010000000
[2023-09-06 16:06:20.896] [ 253.431535] x23: 0000000000000cc0 x22: 0000000000000001
[2023-09-06 16:06:20.900] [ 253.437011] x21: 0000000000000010 x20: 0000000000001000
[2023-09-06 16:06:20.905] [ 253.442495] x19: ffffb738698d71b0 x18: 0000000000000000
[2023-09-06 16:06:20.911] [ 253.447965] x17: 0000000000000000 x16: ffffb73869d3c600
[2023-09-06 16:06:20.916] [ 253.453446] x15: 0000aaaadfa2b8f0 x14: 0d320cbec37540de
[2023-09-06 16:06:20.922] [ 253.458941] x13: d0e63243f5ebbdd3 x12: 0000000000000001
[2023-09-06 16:06:20.928] [ 253.464425] x11: 0000000000000000 x10: 0000000000000001
[2023-09-06 16:06:20.934] [ 253.469909] x9 : 0000000007fff7f9 x8 : 00000000000001ff
[2023-09-06 16:06:20.941] [ 253.475384] x7 : 0000000000000a20 x6 : ffffb738698d71b0
[2023-09-06 16:06:20.943] [ 253.480864] x5 : 0000000000000cc0 x4 : fffffdffbfff0000
[2023-09-06 16:06:20.951] [ 253.486344] x3 : ffff800010000000 x2 : ffffb7386995e090
[2023-09-06 16:06:20.958] [ 253.491829] x1 : 0000000000000001 x0 : 0000000000000302
[2023-09-06 16:06:20.963] [ 253.497313] Call trace:
[2023-09-06 16:06:20.963] [ 253.499839] __get_vm_area_node.isra.0+0x160/0x180
[2023-09-06 16:06:20.966] [ 253.504778] vmap+0x98/0x110
[2023-09-06 16:06:20.969] [ 253.507754] dma_common_pages_remap+0x40/0x70
[2023-09-06 16:06:20.974] [ 253.512246] iommu_dma_alloc_remap+0x2d0/0x420
[2023-09-06 16:06:20.977] [ 253.516824] iommu_dma_alloc+0x274/0x310
[2023-09-06 16:06:20.982] [ 253.520865] dma_alloc_attrs+0xe8/0xf0
[2023-09-06 16:06:20.986] [ 253.524730] tegra_se_ccm_ctr+0x3dc/0x510
[2023-09-06 16:06:20.991] [ 253.528871] tegra_se_aes_ccm_decrypt+0x70/0xd0
[2023-09-06 16:06:20.994] [ 253.533547] crypto_aead_decrypt+0x48/0x70
[2023-09-06 16:06:21.000] [ 253.537817] aead_decrypt+0x138/0x190 [mac80211]
[2023-09-06 16:06:21.007] [ 253.542616] ieee80211_crypto_ccmp_decrypt+0x330/0x360 [mac80211]
[2023-09-06 16:06:21.011] [ 253.548942] ieee80211_rx_handlers+0xdac/0x2240 [mac80211]
[2023-09-06 16:06:21.018] [ 253.554635] ieee80211_prepare_and_rx_handle+0x580/0x1050 [mac80211]
[2023-09-06 16:06:21.024] [ 253.561224] ieee80211_rx_list+0x42c/0x9a0 [mac80211]
[2023-09-06 16:06:21.029] [ 253.566459] ieee80211_rx_napi+0x60/0xe0 [mac80211]
[2023-09-06 16:06:21.041] [ 253.571487] _rtl_usb_rx_process_noagg+0x1b0/0x1f0 [rtl_usb]
[2023-09-06 16:06:21.041] [ 253.577334] _rtl_rx_work+0x80/0x160 [rtl_usb]
[2023-09-06 16:06:21.044] [ 253.581916] tasklet_action_common.isra.0+0x15c/0x180
[2023-09-06 16:06:21.048] [ 253.587121] tasklet_action+0x30/0x40
[2023-09-06 16:06:21.052] [ 253.590892] __do_softirq+0x140/0x3e8
[2023-09-06 16:06:21.060] [ 253.594662] irq_exit+0xc0/0xe0
[2023-09-06 16:06:21.060] [ 253.597891] __handle_domain_irq+0x74/0xd0
[2023-09-06 16:06:21.063] [ 253.602109] gic_handle_irq+0x68/0x134
[2023-09-06 16:06:21.066] [ 253.605976] el1_irq+0xd0/0x180
[2023-09-06 16:06:21.070] [ 253.609219] cpuidle_enter_state+0xb8/0x410
[2023-09-06 16:06:21.075] [ 253.613524] cpuidle_enter+0x40/0x60
[2023-09-06 16:06:21.079] [ 253.617215] call_cpuidle+0x44/0x80
[2023-09-06 16:06:21.081] [ 253.620810] do_idle+0x208/0x270
[2023-09-06 16:06:21.086] [ 253.624142] cpu_startup_entry+0x2c/0x70
[2023-09-06 16:06:21.090] [ 253.628184] rest_init+0xdc/0xe8
[2023-09-06 16:06:21.094] [ 253.631521] arch_call_rest_init+0x18/0x20
[2023-09-06 16:06:21.096] [ 253.635740] start_kernel+0x514/0x54c
[2023-09-06 16:06:21.103] [ 253.639514] Code: a94363f7 a9446bf9 a8c57bfd d65f03c0 (d4210000)
[2023-09-06 16:06:21.107] [ 253.645794] —[ end trace 7f8ee6671a4ca7ef ]—
[2023-09-06 16:06:21.132] [ 253.665957] Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt
[2023-09-06 16:06:21.134] [ 253.673590] SMP: stopping secondary CPUs
[2023-09-06 16:06:21.149] [ 253.677769] Kernel Offset: 0x3738597a0000 from 0xffff800010000000
[2023-09-06 16:06:21.149] [ 253.684059] PHYS_OFFSET: 0xffff938b40000000
[2023-09-06 16:06:21.150] [ 253.688367] CPU features: 0x0040006,4a80aa38
[2023-09-06 16:06:21.153] [ 253.692768] Memory Limit: none
[2023-09-06 16:06:21.181] [ 253.711300] —[ end Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt ]—
[2023-09-06 16:08:09.081] \FF\E2
