USB2.0 HighSpeed, Downstream, Packet Parameters Test
We are considering conducting USB Compliance test on our custom board utilizing OrinNX. Following the document from “Jetson Orin NX Series and Jetson Orin Nano Series Tuning and Compliance Guide Application Note”, I understand that USB Compliance test using various test modes can be performed by modifying registers. However, the document does not clarify how to test the USB 2.0 HighSpeed, Downstream, Packet Parameters Test.
In the current Orin NX environment, are there any convenient test mode registers or tools available for conducting the USB 2.0 HighSpeed, Downstream, Packet Parameters Test? I would appreciate it if you could provide information on these if they exist.
Thank you in advance.
No, what we can provide are the methods listed in Tuning Guide doc.
I understand that “Packet Parameters Test” is not supported. Thank you for your response.
