USB2_0 Hub error
   On My Own design board have two group RTS5420 USB hub through USB2_0 and USB2_3,I Connect four usb3.0 camera to USB2_3 HUB its work well.
   Connect one usb3.0 camera to USB2_0 HUB its work well,but Connect two or more usb3.0 camera to USB2_0 HUB some error happen.dmesg show these informaton "[ 5068.550248] tegra-xusb 3610000.usb: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 2 comp_code 4 tegra-xusb 3610000.usb: Looking for event-dma 0000007fffee6960 trb-start 0000007fffee6970 trb-end 0000007fffee6970 seg-start 0000007fffee6000 seg-end 0000007fffee6ff0"
  USB2_0 Hub and USB2_3 Hub is same design on board ,why USB2_0 Hub only can Connect one usb3.0 camera?
May I review the device tree?
	padctl@3520000 {
		compatible = "nvidia,tegra234-xusb-padctl";
		reg = <0x00 0x3520000 0x00 0x20000 0x00 0x3540000 0x00 0x10000>;
		reg-names = "padctl\0ao";
		interrupts = <0x00 0xa7 0x04>;
		resets = <0x03 0x72>;
		reset-names = "padctl";
		status = "okay";
		vclamp-usb-supply = <0xf7>;
		avdd-usb-supply = <0xf8>;
		phandle = <0xfa>;
		pads {
			usb2 {
				clocks = <0x03 0xa5>;
				clock-names = "trk";
				lanes {
					usb2-0 {
						nvidia,function = "xusb";
						status = "okay";
						#phy-cells = <0x00>;
						phandle = <0xfb>;
					usb2-1 {
						status = "okay";
						phandle = <0xfc>;
					usb2-2 {
						status = "okay";
						phandle = <0xfd>;
					usb2-3 {
						status = "okay";
						phandle = <0xfe>;
			usb3 {
				lanes {
					usb3-0 {
						status = "okay";
						phandle = <0xff>;
					usb3-1 {
						status = "okay";
						phandle = <0x100>;
					usb3-2 {
						status = "okay";
						phandle = <0x101>;
					usb3-3 {
						status = "disabled";
		ports {
			usb2-0 {
				status = "okay";
				vbus-supply = <0xf9>;
				mode = "host";
			usb2-1 {
				status = "okay";
				mode = "host";
			usb2-2 {
				status = "okay";
				mode = "host";
			usb2-3 {
				status = "okay";
				mode = "host";
			usb3-0 {
				status = "ok";
				nvidia,usb2-companion = <0x01>;
			usb3-1 {
				status = "ok";
				nvidia,usb2-companion = <0x00>;
			usb3-2 {
				status = "ok";
				nvidia,usb2-companion = <0x03>;
			usb3-3 {
	usb@3550000 {
		compatible = "nvidia,tegra234-xudc";
		reg = <0x00 0x3550000 0x00 0x8000 0x00 0x3558000 0x00 0x8000>;
		reg-names = "base\0fpci";
		interrupts = <0x00 0xa6 0x04>;
		clocks = <0x03 0x109 0x03 0x10c 0x03 0x113 0x03 0x110>;
		clock-names = "dev\0ss\0ss_src\0fs_src";
		interconnects = <0x58 0x4c 0x59 0x58 0x4d 0x59>;
		interconnect-names = "dma-mem\0write";
		iommus = <0xf3 0x0f>;
		power-domains = <0x03 0x0b 0x03 0x0a>;
		power-domain-names = "dev\0ss";
		nvidia,xusb-padctl = <0xfa>;
		dma-coherent;
		status = "disable";
	usb@3610000 {
		compatible = "nvidia,tegra234-xusb";
		reg = <0x00 0x3610000 0x00 0x40000 0x00 0x3600000 0x00 0x10000 0x00 0x3650000 0x00 0x10000>;
		reg-names = "hcd\0fpci\0bar2";
		clocks = <0x03 0x10b 0x03 0x10d 0x03 0x10c 0x03 0x113 0x03 0x0e 0x03 0x110 0x03 0x67 0x03 0x0e 0x03 0x64>;
		clock-names = "xusb_host\0xusb_falcon_src\0xusb_ss\0xusb_ss_src\0xusb_hs_src\0xusb_fs_src\0pll_u_480m\0clk_m\0pll_e";
		interconnects = <0x58 0x4a 0x59 0x58 0x4b 0x59>;
		iommus = <0xf3 0x0e>;
		power-domains = <0x03 0x0c 0x03 0x0a>;
		power-domain-names = "xusb_host\0xusb_ss";
		dma-coherent;
		status = "ok";
		phys = <0xfb 0xfc 0xfd 0xfe 0xff 0x100 0x101>;
		phy-names = "usb2-0\0usb2-1\0usb2-2\0usb2-3\0usb3-0\0usb3-1\0usb3-2";
		interrupts-extended = <0x01 0x00 0xa3 0x04 0x01 0x00 0xa4 0x04 0x102 0x4c 0x04 0x102 0x4d 0x04 0x102 0x4e 0x04 0x102 0x4f 0x04 0x102 0x50 0x04 0x102 0x51 0x04 0x102 0x52 0x04>;
		interrupt-names = "xhci\0mbox\0wake0\0wake1\0wake2\0wake3\0wake4\0wake5\0wake6";
device-tree.txt (321.3 KB)
~1014
Do you have full dmesg of below test cases?
  1. Single USB test on HUB1
  2. Single USB test on HUB2
  3. 2 USB devices test on HUB1+HUB2
