USB3.0 layout
关于USB3.0布线线距有问题,我在这篇文档中关于pair-pair间距要求是4x/3x的单位不明确,dielectric指的是线宽么?
Dielectric is the material between copper layers; the distance between trace and adjacent reference plane. They recommend you space TX and RX pairs 4x or 3x dielectric apart.
Thanks for mhd0425 for the explanation. Yes as said, you can also find below info in same doc.
tanks your reply!
I want to know the differential signal trace spacing about usb3.0 and pcie? i.e PCIE0_TX1_N and PCIE0_TX1_P
What do you mean? As said, it depends on your PCB board stack-up as the space is based on dielectric. If you mean the space b/w TX/RX, it is as below info.
TX and RX should not be routed on the same layer. If this is required in a design, they should not be interleaved, and the spacing between the closest RX and TX lanes must be 9x Dielectric height spacing.
谢谢你的回复;
关于USB3.0信号线过孔的形式,我还有个疑问,我看推荐的是这种形式,如图片
是否能改成下面这种常规的设计,如图片
