Hi, similar to you another topic 10G PHY for Orin based design, you might need to check with vendor first and make custom design based on Orin Design Guide.
Related topics
| Agx orin use jetson36.4.3 usb hub not work | 7 | 188 | August 13, 2025 | |
| RTS5420 - Component needed in custom carrier board? | 3 | 193 | January 16, 2025 | |
| AGX ORIN 32G由Jetpack5.1.3升级到6.2后 USB不能用了 | 5 | 163 | August 6, 2025 | |
| To create 2 pairs USB3.2 in ORIN NX module, how to find the USB3.2 companion ports in USB2.0 PHY | 2 | 26 | March 30, 2026 | |
| Jetson AGX Orin (P3737) – RTS5420 hub only enumerates at USB2 (480 Mb/s) | 8 | 93 | October 27, 2025 | |
| Direct USB 3.0 on jetson AGX ORING [no hub] | 8 | 102 | February 3, 2026 | |
| AGX Orin使用lsusb无法识别USB | 28 | 833 | November 5, 2024 | |
| Usb3-0 is not working | 20 | 359 | March 29, 2025 | |
| AGX ORIN 32G在JETPACK5.1.5上USB只能识别到USB2.0 | 11 | 130 | November 18, 2025 | |
| AGX Orin industrial Usb3.0 not working | 8 | 202 | March 24, 2025 |
