USD Composer cant connect to Nucleus server with SSL
I have a problem with connecting from USD Composer 2023.2.5 to Nucleus server when Nucleus running with SSL.
When Nucleus running without SSL, Composer connects normally, but if I turn on SSL, Composer says “unable to connect server, please check your internet connection…” and does not open the browser for login.(more in attachment) I tried without SSL port with SSL port (443) and noSSL for comparison.
Connecting to Nucleus from a browser also works for both SSL and noSSL.
I tried from CMD “start https://server” and it works, browser open the address.
Any idea what to do with it?
Thank you.
SSL_noSSL.txt (9.2 KB)
Yes I have answered this question before. Nucleus do not work with SSL. You answer your own question right at the start. “When Nucleus running without SSL, Composer connects normally”. Yes that is because Nucleus is NOT designed to run with SSL. SSL is for encrypting external traffic. Nucleus does not work with external traffic. It is an INTERNAL system only. Therefore no-one would run SSL on an internal network.
I hope I have answered your question well.
