USD composer crashes when start VR
I am trying to connect my Meta Quest 3 to Ominverse. I try to enable VR from “Window” > “Rendering” > “VR” in USD Composer. When I click “Start VR”, then USD composer crash and disappear without any error messages. I tried this in several machines in my office, it all has the same issue. Therefore, I think it is easily to re-create this problem. I am running USD composer version 2023.2.5-prod.3
If you have tried several machines, then it sounds like it is not compatible with your Headset. Or you need specific drivers or something. How is everything else inside Composer ? Good ? You can open scenes, render, do non VR stuff ? I use the VR a lot in composer so I know it works well. I have a VIVE headset. Can you borrow a different headset ?
What is your computer specs ? Make sure you are only attempting to enter VR mode when you are in the REALTIME mode and not path tracing mode.
Hi Richard,
Thanks for your reply. I have solved the problem by enable all related OpenXR and AR extensions. Since I am not sure which exactly extensions should be enabled, then I enable all the OpenXR /AR extensions.
By the way, could you show me how do I known I am entering VR mode in REALTIME mode or path tracing mode.
