hello,
I downloaded the iOS Steaming Client. Got it working once, for ~20-30 secs-- connected to the latest USD Composer.
But then Composer hangs. I have to Win-D to desktop or my entire machine grinds to a halt. Once USD Composer is minimized, I can regain control of the mouse. The iPhone is connected via wifi to the LAN. The goal is to run over wireguard VPN to a remote collaborator so they can see the stage. So, I’m testing locally as the collaborator has latest iPad and iPhone and would like to see the output in AR.
NOTE: occurs in default scene with and without a cube.
GPU: RTX 4090
DirectX 12
USD Composer 2023.2.5
Omniverse Streaming Client 1.3.4
iOS Version: 17.3.1
Model iPhone 12 Pro Max
I have captured the terminal output and logs.
Not sure if it helps, but I have found in UDP Packets in Wireshark that there are periodically malformed packets:
Frame 246629: 78 bytes on wire (624 bits), 78 bytes captured (624 bits) on interface \Device\NPF_{B34A5BFA-7DC0-4D4C-BA2A-5BB38EFCD389}, id 0
Section number: 1
Interface id: 0 (\Device\NPF_{B34A5BFA-7DC0-4D4C-BA2A-5BB38EFCD389})
Encapsulation type: Ethernet (1)
Arrival Time: Apr 9, 2024 07:08:52.609619000 Central Daylight Time
[Time shift for this packet: 0.000000000 seconds]
Epoch Time: 1712664532.609619000 seconds
[Time delta from previous captured frame: 0.501178000 seconds]
[Time delta from previous displayed frame: 0.501178000 seconds]
[Time since reference or first frame: 5183.799220000 seconds]
Frame Number: 246629
Frame Length: 78 bytes (624 bits)
Capture Length: 78 bytes (624 bits)
[Frame is marked: False]
[Frame is ignored: False]
[Protocols in frame: eth:ethertype:ip:udp:rtcp]
[Coloring Rule Name: UDP]
[Coloring Rule String: udp]
Ethernet II, Src: c6:94:a4:af:09:0c (c6:94:a4:af:09:0c), Dst: Dell_14:bb:d6 (cc:96:e5:14:bb:d6)
Destination: Dell_14:bb:d6 (cc:96:e5:14:bb:d6)
Source: c6:94:a4:af:09:0c (c6:94:a4:af:09:0c)
Type: IPv4 (0x0800)
Internet Protocol Version 4, Src: 192.168.1.164, Dst: 192.168.1.163
0100 .... = Version: 4
.... 0101 = Header Length: 20 bytes (5)
Differentiated Services Field: 0x00 (DSCP: CS0, ECN: Not-ECT)
Total Length: 64
Identification: 0xa52a (42282)
000. .... = Flags: 0x0
...0 0000 0000 0000 = Fragment Offset: 0
Time to Live: 64
Protocol: UDP (17)
Header Checksum: 0x50eb [validation disabled]
[Header checksum status: Unverified]
Source Address: 192.168.1.164
Destination Address: 192.168.1.163
User Datagram Protocol, Src Port: 51742, Dst Port: 48005
Source Port: 51742
Destination Port: 48005
Length: 44
Checksum: 0xbe6a [unverified]
[Checksum Status: Unverified]
[Stream index: 899]
[Timestamps]
UDP payload (36 bytes)
Real-time Transport Control Protocol (Receiver Report)
10.. .... = Version: RFC 1889 Version (2)
..0. .... = Padding: False
...1 0110 = Reception report count: 22
Packet type: Receiver Report (201)
Length: 47085 (188344 bytes)
Sender SSRC: 0x0f1a9f37 (253402935)
Source 1
[Malformed Packet: RTCP]
[Expert Info (Error/Malformed): Malformed Packet (Exception occurred)]
[Malformed Packet (Exception occurred)]
[Severity level: Error]
[Group: Malformed]
Here’s the relevant terminal output of omni.create.bat:
[11.918s] RTX ready
06:54:08.883 I (dll_attach) DLL_PROCESS_ATTACH
06:54:08.884 I (CXRServerUtils) Successfully loaded CloudXR server library.
06:54:08.886 I (Logger) Base dir set to: C:\Users\nickarthur\AppData\Local\NVIDIA\CloudXR\\logs\
06:54:08.888 I (deleteOlderFiles) Cleaning up older temp files from: C:\Users\nickarthur\AppData\Local\NVIDIA\CloudXR\\logs\
06:54:08.890 I (deleteOlderFiles) Old temp files purged.
06:54:08.891 I (Logger::Init) NVIDIA CloudXR v3.3.1 (CL# 32443542), built on Feb 13 2023 20:44:55.
06:54:08.892 I (FrameServer::FrameServer) Server features - Send audio: Y, Receive audio: N, Two-pass foveation: N, Pose prediction: Y, VVSync: N, Authorization: N
06:54:08.895 I (FrameServerCuda::FrameServerCuda) Starting FrameServerCuda.
06:54:08.896 I (netStreamServer::LoadNvstServer) Loading stream server library from d:\users\nickarthur\appdata\local\ov\pkg\create-2023.2.5\extscache\omni.kit.xr.system.cloudxr-105.1.0-192+105.1.wx64.r.cp310\bin.
06:54:09.063 I (netStreamServer::Init) Stream server created.
06:54:09.064 I (netStreamServer::Init) CloudXR video streams created.
06:54:09.065 I (netStreamServer::Init) Input stream created.
06:54:09.066 I (netStreamServer::Init) Audio send stream created.
06:54:09.076 I (netStreamServer::Init) Streaming instance started - waiting for a client...
2024-04-09 11:54:09 [16,137ms] [Warning] [omni.hydra] Disabling DLSS Frame Generation for at least one view due to output contains alpha
06:54:20.619 I (FrameServer::ProcessAuthorizationHeader) Authorization disabled bypass header check
06:54:20.622 I (FrameServer::ProcessVersionHeader) Version check succesful
06:54:20.623 I (netStreamServer::ProcessSignalingHeaders) Client headers accepted, connecting.
06:54:21.035 I (FrameServer::OnNewConnection) FrameServer::OnNewConnection()
06:54:21.036 I (CloudXRServer::OnConnect) Server State Connected
06:54:21.037 I (netStreamServer::ProcessClientConnectionEvent) Client connected.
06:54:21.038 I (netStreamServer::ProcessStreamConnectionEvent) Stream type 4 connected.
06:54:21.039 I (netStreamServer::ProcessStreamConnectionEvent) Input Stream connected.
06:54:21.041 I (netStreamServer::ProcessStreamConnectionEvent) Stream type 1 connected.
06:54:21.042 I (netStreamServer::connectVideoStream) netStreamServer::connectVideoStream streamSource=0xdb6edba0, m_streams[VIDEO_STREAM0]=0xdb6edba0 m_connectedVideoStreams=1
06:54:21.045 I (netStreamServer::ProcessStreamConnectionEvent) Stream type 1 connected.
06:54:21.047 I (netStreamServer::connectVideoStream) netStreamServer::connectVideoStream streamSource=0xdb6ec520, m_streams[VIDEO_STREAM1]=0xdb6ec520 m_connectedVideoStreams=2
06:54:21.050 I (netStreamServer::ProcessStreamConnectionEvent) Stream type 2 connected.
06:54:21.051 I (netStreamServer::ProcessStreamConnectionEvent) Audio Send Stream connected.
06:54:21.053 I (netStreamServer::ProcessStreamConnectionEvent) All Streams connected.
06:54:21.055 I (FrameServer::OnStartStreaming) Waiting until client config recevied, skip OnStartStreaming()
06:54:21.066 I (CloudXRServer::HandleDeviceDescriptor) Connection established. Client type: 1
06:54:21.067 I (CloudXRServer::OnStartStreaming) Server State Running
06:54:32.295 I (netStreamServer::ProcessStreamConnectionEvent) Stream type 1 stopped.
06:54:32.296 I (netStreamServer::ProcessStreamConnectionEvent) Stream type 1 stopped.
06:54:32.297 I (netStreamServer::ProcessStreamConnectionEvent) Stream type 4 stopped.
06:54:32.299 I (netStreamServer::ProcessStreamConnectionEvent) All streams stopped.
06:54:32.300 I (netStreamServer::ProcessStreamConnectionEvent) Stream type 2 stopped.
06:54:32.301 I (netStreamServer::StreamFrame) Skipping nvstPushStreamData for eye 0 because the connection has been torn down.
06:54:32.302 E (netStreamServer::StreamFrame) Cannot send video because all streams are not connected.
06:54:32.304 I (netStreamServer::ProcessClientConnectionEvent) Client disconnected.
2024-04-09 11:54:35 [41,460ms] [Warning] [omni.hydra] Disabling DLSS Frame Generation for at least one view due to output contains alpha
2024-04-09 11:55:47 [113,870ms] [Warning] [omni.kit.xr.core.plugin] Render thread failed to render frame 4383
2024-04-09 11:55:49 [115,875ms] [Warning] [omni.kit.xr.core.plugin] Render thread failed to render frame 4384
2024-04-09 11:55:51 [117,879ms] [Warning] [omni.kit.xr.core.plugin] Render thread failed to render frame 4385
2024-04-09 11:55:53 [119,884ms] [Warning] [omni.kit.xr.core.plugin] Render thread failed to render frame 4386
2024-04-09 11:55:55 [121,889ms] [Warning] [omni.kit.xr.core.plugin] Render thread failed to render frame 4387
2024-04-09 11:55:57 [123,893ms] [Warning] [omni.kit.xr.core.plugin] Render thread failed to render frame 4388
2024-04-09 11:55:59 [125,897ms] [Warning] [omni.kit.xr.core.plugin] Render thread failed to render frame 4389
2024-04-09 11:56:01 [127,902ms] [Warning] [omni.kit.xr.core.plugin] Render thread failed to render frame 4390
Application Event Log:
+ System
- Provider
[ Name] Application Error
[ Guid] {a0e9b465-b939-57d7-b27d-95d8e925ff57}
EventID 1000
Version 0
Level 2
Task 100
Opcode 0
Keywords 0x8000000000000000
- TimeCreated
[ SystemTime] 2024-04-09T11:09:14.8062429Z
EventRecordID 187212
Correlation
- Execution
[ ProcessID] 53896
[ ThreadID] 52868
Channel Application
Computer ALICIA
- Security
[ UserID] S-1-5-21-448746131-888087067-1709255794-1001
- EventData
AppName kit.exe
AppVersion 0.0.0.0
AppTimeStamp 65aaefa9
ModuleName omni.kit.xr.core.plugin.dll
ModuleVersion 0.0.0.0
ModuleTimeStamp ecbdfcb7
ExceptionCode c0000005
FaultingOffset 0000000000041473
ProcessId 0x7aa8
ProcessCreationTime 0x1da8a6c2ae735b6
AppPath D:\Users\nickarthur\AppData\Local\ov\pkg\create-2023.2.5\kit\kit.exe
ModulePath d:\users\nickarthur\appdata\local\ov\pkg\create-2023.2.5\extscache\omni.kit.xr.core-105.1.0-192+105.1.wx64.r.cp310\bin\omni.kit.xr.core.plugin.dll
IntegratorReportId 309a0d66-5dcb-4485-af01-41cfd0727ee8
PackageFullName
PackageRelativeAppId
Please Help
Here’s DXDiag Output:
DxDiag.txt (118.7 KB)
Here’s the CloudXR Server Log:
CloudXR Server – Native Log 2024-04-09 06.54.08.txt (3.4 KB)
Streamer Server Log:
Streamer Server Log 2024-04-09 06.54.08.txt (291.3 KB)
Thanks,
Nick
