USDZ files built using the official Nurec workflow fail to open in Isaac Sim, and the captured image content appears completely black
Important: Isaac Sim support
Note: For Isaac Sim support, the community is gradually transitioning from this forum to the Isaac Sim GitHub repository so that questions and issues can be tracked, searched, and resolved more efficiently in one place. Whenever possible, please create a GitHub Discussion or Issue there instead of starting a new forum topic.
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim · GitHub ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
Isaac Sim Version
6.0.1
6.0.0
5.1.0
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 24.04
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model:
  • Driver Version:
Topic Description
USDZ files built using the official Nurec workflow fail to open in Isaac Sim, and the captured image content appears completely black.
Detailed Description
First, I generated USDZ files built using the official open-source dataset by following NuRec’s official workflow. Since I connect remotely to the A800 server, I can only view rendering outputs by exporting rendered frames. Unfortunately, all exported images have entirely black backgrounds.
Steps to Reproduce
  1. get usdz file
    docker run --shm-size=64g --rm --gpus all \ -e NGC_API_KEY=${NGC_API_KEY} \ --volume <DATASET_DIR>:/workdir/dataset \ --volume <OUTPUT_DIR>:/workdir/output \ --volume /path/to/instant_nurec_output:/workdir/instant_nurec \ ``nvcr.io/nvidia/nre/nre-ga:26.04`` \ mode=train \ out_dir=/workdir/output \ --config-name=configs/apps/prod/Hyperion-8.1/car2sim_6cam.yaml \ dataset.path=/workdir/dataset/pai_<CLIP_ID>.json \ dataset.camera_ids=[<CAM1>,<CAM2>,<CAM3>] \ dataset.lidar_ids=[lidar_top_360fov] \ dataset.aux_data=True \ model/gaussians/initialization@model.layers.background.initialization=nrm_ply \ model.layers.background.initialization.path=/workdir/instant_nurec/merged.ply \ model.layers.background.initialization.num_point_cloud_points=2000000 \ dataset.n_samples_per_epoch=30000 \ model.layers.background.optimizers.0.params.positions.args.lr=5.06e-5 \ model.layers.dynamic_rigids.optimizers.0.params.positions.args.lr=4e-5
  2. Obtain rendered frames programmatically and save them as image files.
    import os
    import carb
    from isaacsim import SimulationApp
    simulation_app = SimulationApp(launch_config={
    "headless": True,
    "width": 1920,
    "height": 1080
    import omni.usd
    import omni.kit.app
    import omni.timeline
    from pxr import UsdGeom
    ext_manager = omni.kit.app.get_app().get_extension_manager()
    ext_manager.set_extension_enabled_immediate("omni.ujitso.default", True)
    ext_manager.set_extension_enabled_immediate("omni.hydra.rtx", True)
    carb.settings.get_settings().set_bool("/UJITSO/geometry", True)
    def get_nurec_cameras(stage):
    cameras = []
    for prim in stage.Traverse():
    if prim.IsA(UsdGeom.Camera):
    cameras.append(str(prim.GetPath()))
    return cameras
    def main():
    nurec_usd_path = "/workspace/test/last.usdz"
    usd_context = omni.usd.get_context()
    if not usd_context.open_stage(nurec_usd_path):
    print(f"Failed to open scene path: {nurec_usd_path}")
    return
    stage = usd_context.get_stage()
    output_dir = "/workspace/rendered_frames"
    os.makedirs(output_dir, exist_ok=True)
    camera_paths = get_nurec_cameras(stage)
    if not camera_paths:
    print("Warning: No built-in camera detected in the scene!")
    return
    selected_camera_path = camera_paths[0]
    print(f"{len(camera_paths)} built-in camera(s) detected. Binding camera: {selected_camera_path}")
    render_product = rep.create.render_product(selected_camera_path, resolution=(1920, 1080))
    rgb_annotator = rep.AnnotatorRegistry.get_annotator("rgb")
    rgb_annotator.attach([render_product])
    timeline = omni.timeline.get_timeline_interface()
    timeline.play()
    print("Warming up the renderer (waiting for 3DGS volume rendering to load)...")
    for _ in range(100):
    simulation_app.update()
    print("Start exporting rendered frames...")
    for frame_idx in range(50):
    data = rgb_annotator.get_data()
    if data is not None and len(data) > 0:
    import PIL.Image
    img = PIL.Image.fromarray(data)
    img_path = os.path.join(output_dir, f"frame_{frame_idx:04d}.png")
    img.save(img_path)
    if frame_idx % 10 == 0:
    print(f"Frame {frame_idx} successfully saved to: {img_path}")
    timeline.stop()
    if __name__ == "__main__":
    main()
    simulation_app.close()
  3. The last result
Updating server information
Rendering works correctly when using the official render command provided by Nurec.
docker run --shm-size=64g -it --rm --gpus all
--network host
--volume /home/koala/workspace/dhj/nre_docker/nre:/workdir/output
-- render
--artifact-path /workdir/output/output/bjpAtJaR8nnQQSHHdAcvYe/artifacts/last.usdz
--output-dir /workdir/output/renders
--camera-id camera_front_wide_120fov
--frame-step 1
--image-scale 0.5
--image-format png
--replicate-training-views
The difference may be in the Isaac Sim capture setup.
Your script enables UJITSO and Hydra, but NuRec SPG/PPISP assets require single-GPU rendering, omni.rtx.spg, and specific settings applied before the first Hydra sync. Try adding these:
--/renderer/multiGpu/enabled=false
--enable omni.rtx.spg
--/rtx/spg/enabled=true
--/omni/rtx/nre/compositing/disableNuRecPostProcessings=true
--/rtx/rtpt/gaussian/skipTonemapping/enabled=false
The relevant NuRec Rendering Utilities documentation requires single-GPU rendering, omni.rtx.spg, the NuRec-specific post-processing settings. I recommend testing with the documented nurec_render.py utility first because it detects the asset type and applies the appropriate setup automatically
