Use 4 CPU for Multithreading using C in xavier NX
Hi ShaneCC,
Thanks for your support, In echo 1036800000 > vi/rate ,it’s reading 4fps.
Could you enable the trace log the check SOF interval.
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
echo > /sys/kernel/debug/tracing/trace
cat /sys/kernel/debug/tracing/trace
Hi ShaneCC,
Thanks for your support, Here I have attached my trace log.
Thanks for your timetrace.log (190.2 KB)
The trace log show the SOF interval is 0.32xx seconds that tell output just about 3 -4 fps only.
Hi ShaneCC,
Thanks for your support, How to increase it speed. Could you suggest any Idea.
Here I have attached my clock detais
sudo /usr/bin/jetson_clocks --show
SOC family:tegra194 Machine:NVIDIA Jetson Xavier NX Developer Kit
Online CPUs: 0-5
CPU Cluster Switching: Disabled
cpu0: Online=1 Governor=schedutil MinFreq=1420800 MaxFreq=1420800 CurrentFreq=1420800 IdleStates: C1=0 c6=0
cpu1: Online=1 Governor=schedutil MinFreq=1420800 MaxFreq=1420800 CurrentFreq=1420800 IdleStates: C1=0 c6=0
cpu2: Online=1 Governor=schedutil MinFreq=1420800 MaxFreq=1420800 CurrentFreq=1420800 IdleStates: C1=0 c6=0
cpu3: Online=1 Governor=schedutil MinFreq=1420800 MaxFreq=1420800 CurrentFreq=1420800 IdleStates: C1=0 c6=0
cpu4: Online=1 Governor=schedutil MinFreq=1420800 MaxFreq=1420800 CurrentFreq=1420800 IdleStates: C1=0 c6=0
cpu5: Online=1 Governor=schedutil MinFreq=1420800 MaxFreq=1420800 CurrentFreq=1420800 IdleStates: C1=0 c6=0
GPU MinFreq=1109250000 MaxFreq=1109250000 CurrentFreq=1109250000
EMC MinFreq=204000000 MaxFreq=1600000000 CurrentFreq=1600000000 FreqOverride=1
Fan: speed=0
NV Power Mode: MODE_15W_6CORE
I think it couldn’t be the system performance cause the problem.
From the trace I think it could be the sensor output problem.
Hi ShaneCC,
Thanks for your support, I will check with my team, Could please give any suggestion for this Multi Virtual Channel Implementation in a CSI port using Xavier NX - #59 by JerryChang.
Hi ShaneCCC,
Actually I missed to enable echo 2 > /sys/kernel/debug/camrtc/log-level. After enabling it, it’s showing some trace could you please check it and give some idea. sorry
Here I have attached trace.logtrace.log (75.2 KB)
Thanks for your time.
Do you set embedded_metadata_height = 1 in device tree?
And have a confirm the sensor have output embedded data line.
Hi ShaneCC,
Thanks for your support, After adding embedded_metadata_height = 1, it’s not reading anything . Here I have attached my latest trace.log FYI. I will check with my team about whether it’s sending metadata or not and update you.
Thanks for your timeEmbedded_trace.log (44.0 KB)
Hi ShaneCCC,
I have Checked with my team, That the sensor not sending any embedded data line. My sensor send data as a chirp per trigger which contain 32frames and 8 frames per channel. In that I can read 1 frames per VC and others I can’t when am reading in parallel.
Use 4 CPU for Multithreading using C in xavier NX - #28 by PaulEnoch , This trace log is when am reading only one channel, And it’s reading 4frames/2frames out of 8 in a chirp.
Here I have attached trace when am reading data in parallel4VCtrace.log (102.0 KB) .
Could you please suggest any idea
This log show the FS interval for the same channel like 0.000064, does this capture have frame drop too?
 kworker/0:2-10294 [000] ....  9338.911928: rtcpu_vinotify_event: tstamp:292245506141 tag:FS channel:0x00 frame:0 vi_tstamp:292245499130 data:0x00000010
kworker/0:2-10294 [000] … 9338.911992: rtcpu_vinotify_event: tstamp:292245528589 tag:FS channel:0x00 frame:0 vi_tstamp:292245518947 data:0x00000010
Hi ShaneCC,
Thanks for your support, Yes it have frame drop. In 8 frame I can read only 2 or 3 frames, others get dropped. Could you please suggest any solution.
thanks for your time
Can configure output only one channel to clarify?
Hi ShaneCC,
Thanks for your support, When I configure for one VC, Its showing following trace
Here I have attached trace log.
Kindly give any suggestion to over come.
kworker/1:0-9413 [001] … 2202.218212: rtos_queue_send_from_isr_failed: tstamp:69222809672 queue:0x0bcbb3a0
kworker/1:0-9413 [001] … 2202.218213: rtos_queue_send_from_isr_failed: tstamp:69222809817 queue:0x0bcbc160
kworker/1:3-9733 [001] … 2202.273978: rtcpu_vinotify_event: tstamp:69223343837 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:67646406304 data:0x10000000
kworker/1:3-9733 [001] … 2202.273982: rtcpu_vinotify_event: tstamp:69223344004 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:67646435744 data:0x31000001
kworker/1:3-9733 [001] … 2202.273984: rtcpu_vinotify_event: tstamp:69223344143 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:67646445952 data:0x10000000
kworker/1:3-9733 [001] … 2202.273985: rtcpu_vinotify_event: tstamp:69223344299 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:67646454400 data:0x07020001
kworker/1:3-9733 [001] … 2202.273986: rtcpu_vinotify_event: tstamp:69223344435 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:67646484832 data:0x31000002
kworker/1:3-9733 [001] … 2202.273989: rtos_queue_peek_from_isr_failed: tstamp:69224461547 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2202.441976: rtos_queue_peek_from_isr_failed: tstamp:69229461547 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2202.609963: rtos_queue_peek_from_isr_failed: tstamp:69234461551 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2202.777972: rtos_queue_peek_from_isr_failed: tstamp:69239461549 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2202.945963: rtos_queue_peek_from_isr_failed: tstamp:69244461546 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2203.057970: rtos_queue_peek_from_isr_failed: tstamp:69249461546 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2203.225975: rtos_queue_peek_from_isr_failed: tstamp:69254461547 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2203.393987: rtos_queue_peek_from_isr_failed: tstamp:69259461547 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2203.561963: rtos_queue_peek_from_isr_failed: tstamp:69264461546 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2203.729959: rtos_queue_peek_from_isr_failed: tstamp:69269461543 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2203.897969: rtos_queue_peek_from_isr_failed: tstamp:69274461546 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2204.065962: rtos_queue_peek_from_isr_failed: tstamp:69279461549 queue:0x0bcbcf78
vi-output, imx2-10209 [000] … 2204.073913: tegra_channel_capture_frame: sof:2216.998944224
vi-output, imx2-10209 [000] … 2204.073916: tegra_channel_capture_frame: eof:2216.999101472
vi-output, imx2-10209 [001] … 2204.074609: tegra_channel_capture_frame: sof:2216.999578400
vi-output, imx2-10209 [001] … 2204.074612: tegra_channel_capture_frame: eof:2216.999735616
kworker/1:3-9733 [001] … 2204.121967: rtcpu_vinotify_event: tstamp:69281221171 tag:FS channel:0x00 frame:0 vi_tstamp:69281216979 data:0x00000010
kworker/1:3-9733 [001] … 2204.121972: rtcpu_vinotify_event: tstamp:69281221322 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:69281216982 data:0x00000000
kworker/1:3-9733 [001] … 2204.121980: rtcpu_vinotify_error: tstamp:69281229157 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:69281221961 data:0x00000549
kworker/1:3-9733 [001] … 2204.121981: rtcpu_vinotify_error: tstamp:69281230725 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:69281226916 data:0x00000549
kworker/1:3-9733 [001] … 2204.121983: rtcpu_vinotify_error: tstamp:69281234886 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:69281231870 data:0x00000549
kworker/1:3-9733 [001] … 2204.121984: rtcpu_vinotify_event: tstamp:69281235245 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:69281217007 data:0x00000001
kworker/1:3-9733 [001] … 2204.121985: rtcpu_vinotify_event: tstamp:69281235388 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:69515318304 data:0x08020001
kworker/1:3-9733 [001] … 2204.121986: rtcpu_vinotify_event: tstamp:69281235546 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:69281221882 data:0x00000002
kworker/1:3-9733 [001] … 2204.121987: rtcpu_vinotify_event: tstamp:69281235685 tag:FE channel:0x00 frame:0 vi_tstamp:69281221906 data:0x00000020
kworker/1:3-9733 [001] … 2204.121988: rtcpu_vinotify_event: tstamp:69281235843 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:69281221909 data:0x00000000
kworker/1:3-9733 [001] … 2204.121989: rtcpu_vinotify_event: tstamp:69281235978 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:69281221921 data:0x00000000
kworker/1:3-9733 [001] … 2204.121990: rtcpu_vinotify_event: tstamp:69281236134 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:69515473376 data:0x02020001
kworker/1:3-9733 [001] … 2204.121992: rtcpu_vinotify_event: tstamp:69281236270 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:69515485632 data:0x00020001
kworker/1:3-9733 [001] … 2204.121993: rtcpu_vinotify_event: tstamp:69281236427 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:69515507488 data:0x07020002
kworker/1:3-9733 [001] … 2204.121994: rtcpu_vinotify_event: tstamp:69281236564 tag:FS channel:0x01 frame:0 vi_tstamp:69281221934 data:0x00000010
kworker/1:3-9733 [001] … 2204.121995: rtcpu_vinotify_event: tstamp:69281236718 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:69281221961 data:0x00000549
kworker/1:3-9733 [001] … 2204.121996: rtcpu_vinotify_event: tstamp:69281236853 tag:FE channel:0x01 frame:0 vi_tstamp:69281226861 data:0x00000020
kworker/1:3-9733 [001] … 2204.121997: rtcpu_vinotify_event: tstamp:69281237009 tag:FS channel:0x02 frame:0 vi_tstamp:69281226887 data:0x00000010
kworker/1:3-9733 [001] … 2204.121998: rtcpu_vinotify_event: tstamp:69281237144 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:69281226916 data:0x00000549
kworker/1:3-9733 [001] … 2204.121999: rtcpu_vinotify_event: tstamp:69281237298 tag:FE channel:0x02 frame:0 vi_tstamp:69281231815 data:0x00000020
kworker/1:3-9733 [001] … 2204.122000: rtcpu_vinotify_event: tstamp:69281237430 tag:FS channel:0x03 frame:0 vi_tstamp:69281231843 data:0x00000010
kworker/1:3-9733 [001] … 2204.122002: rtcpu_vinotify_error: tstamp:69281249178 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:69281241779 data:0x00000549
kworker/1:3-9733 [001] … 2204.122004: rtcpu_vinotify_error: tstamp:69281250688 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:69281246733 data:0x00000549
kworker/1:3-9733 [001] … 2204.122006: rtcpu_vinotify_event: tstamp:69281251066 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:69281231870 data:0x00000549
kworker/1:3-9733 [001] … 2204.122007: rtcpu_vinotify_event: tstamp:69281251202 tag:FE channel:0x03 frame:0 vi_tstamp:69281236770 data:0x00000020
kworker/1:3-9733 [001] … 2204.122008: rtcpu_vinotify_event: tstamp:69281251359 tag:FS channel:0x00 frame:0 vi_tstamp:69281236797 data:0x00000010
kworker/1:3-9733 [001] … 2204.122009: rtcpu_vinotify_event: tstamp:69281251499 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:69281236799 data:0x00000000
kworker/1:3-9733 [001] … 2204.122010: rtcpu_vinotify_event: tstamp:69281251661 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:69281236825 data:0x00000001
kworker/1:3-9733 [001] … 2204.122011: rtcpu_vinotify_event: tstamp:69281251799 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:69515947328 data:0x08020002
kworker/1:3-9733 [001] … 2204.122012: rtcpu_vinotify_event: tstamp:69281251956 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:69281241701 data:0x00000002
kworker/1:3-9733 [001] … 2204.122014: rtcpu_vinotify_event: tstamp:69281253584 tag:FE channel:0x00 frame:0 vi_tstamp:69281241725 data:0x00000020
kworker/1:3-9733 [001] … 2204.122015: rtcpu_vinotify_event: tstamp:69281253742 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:69281241727 data:0x00000000
kworker/1:3-9733 [001] … 2204.122016: rtcpu_vinotify_event: tstamp:69281253877 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:69281241738 data:0x00000000
kworker/1:3-9733 [001] … 2204.122017: rtcpu_vinotify_event: tstamp:69281254037 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:69516107616 data:0x02020002
kworker/1:3-9733 [001] … 2204.122018: rtcpu_vinotify_event: tstamp:69281254172 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:69516119840 data:0x00020002
kworker/1:3-9733 [001] … 2204.122019: rtcpu_vinotify_event: tstamp:69281254330 tag:FS channel:0x01 frame:0 vi_tstamp:69281241751 data:0x00000010
kworker/1:3-9733 [001] … 2204.122020: rtcpu_vinotify_event: tstamp:69281254466 tag:CHANSEL_NOMATCH channel:0x41 frame:0 vi_tstamp:69281241779 data:0x00000549
kworker/1:3-9733 [001] … 2204.122021: rtcpu_vinotify_event: tstamp:69281254620 tag:FE channel:0x01 frame:0 vi_tstamp:69281246679 data:0x00000020
kworker/1:3-9733 [001] … 2204.122022: rtcpu_vinotify_event: tstamp:69281254755 tag:FS channel:0x02 frame:0 vi_tstamp:69281246706 data:0x00000010
kworker/1:3-9733 [001] … 2204.122024: rtcpu_vinotify_error: tstamp:69281255821 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:69281251688 data:0x00000549
kworker/1:3-9733 [001] … 2204.122027: rtos_queue_send_from_isr_failed: tstamp:69281305825 queue:0x0bcb41f8
kworker/1:3-9733 [001] … 2204.122028: rtos_queue_send_from_isr_failed: tstamp:69281305979 queue:0x0bcb8a60
kworker/1:3-9733 [001] … 2204.122029: rtos_queue_send_from_isr_failed: tstamp:69281306132 queue:0x0bcba5e0
kworker/1:3-9733 [001] … 2204.122031: rtos_queue_send_from_isr_failed: tstamp:69281306279 queue:0x0bcbb3a0
kworker/1:3-9733 [001] … 2204.122032: rtos_queue_send_from_isr_failed: tstamp:69281306424 queue:0x0bcbc160
kworker/1:3-9733 [001] … 2204.122033: rtos_queue_send_from_isr_failed: tstamp:69281359326 queue:0x0bcb41f8
kworker/1:3-9733 [001] … 2204.122034: rtos_queue_send_from_isr_failed: tstamp:69281359488 queue:0x0bcb8a60
kworker/1:3-9733 [001] … 2204.122035: rtos_queue_send_from_isr_failed: tstamp:69281359637 queue:0x0bcba5e0
kworker/1:3-9733 [001] … 2204.122036: rtos_queue_send_from_isr_failed: tstamp:69281359784 queue:0x0bcbb3a0
kworker/1:3-9733 [001] … 2204.122038: rtos_queue_send_from_isr_failed: tstamp:69281359930 queue:0x0bcbc160
kworker/1:3-9733 [001] … 2204.122039: rtcpu_vinotify_event: tstamp:69281775630 tag:CHANSEL_NOMATCH channel:0x81 frame:0 vi_tstamp:69281246733 data:0x00000549
kworker/1:3-9733 [001] … 2204.122040: rtcpu_vinotify_event: tstamp:69281775773 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:69516403808 data:0x10000000
kworker/1:3-9733 [001] … 2204.122041: rtcpu_vinotify_event: tstamp:69281775935 tag:FE channel:0x02 frame:0 vi_tstamp:69281251633 data:0x00000020
kworker/1:3-9733 [001] … 2204.122042: rtcpu_vinotify_event: tstamp:69281776070 tag:FS channel:0x03 frame:0 vi_tstamp:69281251660 data:0x00000010
kworker/1:3-9733 [001] … 2204.122043: rtcpu_vinotify_event: tstamp:69281776224 tag:CHANSEL_NOMATCH channel:0xc1 frame:0 vi_tstamp:69281251688 data:0x00000549
kworker/1:3-9733 [001] … 2204.122044: rtcpu_vinotify_event: tstamp:69281776363 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:69516488896 data:0x31000003
kworker/1:3-9733 [001] … 2204.122045: rtcpu_vinotify_event: tstamp:69281776523 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:69516497536 data:0x07020003
kworker/1:3-9733 [001] … 2204.122046: rtcpu_vinotify_event: tstamp:69281776659 tag:FE channel:0x03 frame:0 vi_tstamp:69281256588 data:0x00000020
kworker/1:3-9733 [001] … 2204.178004: rtos_queue_peek_from_isr_failed: tstamp:69284461550 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2204.345989: rtos_queue_peek_from_isr_failed: tstamp:69289461547 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2204.513981: rtos_queue_peek_from_isr_failed: tstamp:69294461550 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2204.681963: rtos_queue_peek_from_isr_failed: tstamp:69299461547 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2204.849985: rtos_queue_peek_from_isr_failed: tstamp:69304461547 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2205.017976: rtos_queue_peek_from_isr_failed: tstamp:69309461546 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2205.185966: rtos_queue_peek_from_isr_failed: tstamp:69314461547 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2205.297970: rtos_queue_peek_from_isr_failed: tstamp:69319461546 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2205.466005: rtos_queue_peek_from_isr_failed: tstamp:69324461547 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2205.633962: rtos_queue_peek_from_isr_failed: tstamp:69329461547 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2205.801973: rtos_queue_peek_from_isr_failed: tstamp:69334461547 queue:0x0bcbcf78
kworker/1:3-9733 [001] … 2205.969966: rtos_queue_peek_from_isr_failed: tstamp:69339461547 queue:0x0bcbcf78
Looks like still output 4 channel data. I saw the FS for channel 0 1 2 3
FS channel:0x00/FS channel:0x01/FS channel:0x02/FS channel:0x03
Hi ShaneCC,
That I configure Xavier for one VC and sensor sending 4VC data, Sorry mis understand. Now I tried xavier and sensor enable 1VC config. Here I have attached trace log. thanks
 kworker/0:4-1751  [000] ....   935.097068: rtos_queue_send_from_isr_failed: tstamp:29625081120 queue:0x0bcbc160
 kworker/0:4-1751  [000] ....   935.151394: rtcpu_vinotify_event: tstamp:29625232209 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:28872231968 data:0x10000000
 kworker/0:4-1751  [000] ....   935.151397: rtcpu_vinotify_event: tstamp:29625232357 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:28872247040 data:0x31000001
 kworker/0:4-1751  [000] ....   935.151399: rtcpu_vinotify_event: tstamp:29625232519 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:28872249152 data:0x07020001
 kworker/0:4-1751  [000] ....   935.151400: rtcpu_vinotify_event: tstamp:29625232655 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:28872356384 data:0x10000000
 kworker/0:4-1751  [000] ....   935.151401: rtcpu_vinotify_event: tstamp:29625232812 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:28872364768 data:0x31000002
 kworker/0:4-1751  [000] ....   935.263409: rtos_queue_peek_from_isr_failed: tstamp:29629630670 queue:0x0bcbcf78
 kworker/0:4-1751  [000] ....   935.431385: rtos_queue_peek_from_isr_failed: tstamp:29634630669 queue:0x0bcbcf78
 kworker/0:4-1751  [000] ....   935.599390: rtos_queue_peek_from_isr_failed: tstamp:29639630670 queue:0x0bcbcf78
 kworker/0:4-1751  [000] ....   935.767390: rtos_queue_peek_from_isr_failed: tstamp:29644630670 queue:0x0bcbcf78
 kworker/0:4-1751  [000] ....   935.879394: rtos_queue_peek_from_isr_failed: tstamp:29649630670 queue:0x0bcbcf78
 kworker/0:4-1751  [000] ....   936.047387: rtos_queue_peek_from_isr_failed: tstamp:29654630673 queue:0x0bcbcf78
 kworker/0:4-1751  [000] ....   936.215397: rtos_queue_peek_from_isr_failed: tstamp:29659630670 queue:0x0bcbcf78
 kworker/0:4-1751  [000] ....   936.383384: rtos_queue_peek_from_isr_failed: tstamp:29664630670 queue:0x0bcbcf78
 kworker/0:4-1751  [000] ....   936.551377: rtos_queue_peek_from_isr_failed: tstamp:29669630671 queue:0x0bcbcf78
 kworker/0:4-1751  [000] ....   936.719392: rtos_queue_peek_from_isr_failed: tstamp:29674630671 queue:0x0bcbcf78
 kworker/0:4-1751  [000] ....   936.887384: rtos_queue_peek_from_isr_failed: tstamp:29679630670 queue:0x0bcbcf78
 kworker/0:4-1751  [000] ....   936.999379: rtos_queue_peek_from_isr_failed: tstamp:29684630670 queue:0x0bcbcf78
 kworker/0:4-1751  [000] ....   937.167401: rtos_queue_peek_from_isr_failed: tstamp:29689630669 queue:0x0bcbcf78
 kworker/0:4-1751  [000] ....   937.335392: rtos_queue_peek_from_isr_failed: tstamp:29694630670 queue:0x0bcbcf78
 kworker/0:4-1751  [000] ....   937.503373: rtos_queue_peek_from_isr_failed: tstamp:29699630669 queue:0x0bcbcf78
 kworker/0:4-1751  [000] ....   937.671377: rtos_queue_peek_from_isr_failed: tstamp:29704630671 queue:0x0bcbcf78
vi-output, imx2-8864 [000] … 937.809044: tegra_channel_capture_setup: vnc_id 0 W 32776 H 1 fmt 5
kworker/0:4-1751 [000] … 937.839372: rtos_queue_peek_from_isr_failed: tstamp:29709630670 queue:0x0bcbcf78
kworker/0:4-1751 [000] … 937.839377: rtos_queue_send_from_isr_failed: tstamp:29709800204 queue:0x0bcb41f8
kworker/0:4-1751 [000] … 937.839379: rtos_queue_send_from_isr_failed: tstamp:29709800356 queue:0x0bcb8a60
kworker/0:4-1751 [000] … 937.839380: rtos_queue_send_from_isr_failed: tstamp:29709800509 queue:0x0bcba5e0
kworker/0:4-1751 [000] … 937.839381: rtos_queue_send_from_isr_failed: tstamp:29709800657 queue:0x0bcbb3a0
kworker/0:4-1751 [000] … 937.839382: rtos_queue_send_from_isr_failed: tstamp:29709800814 queue:0x0bcbc160
kworker/0:4-1751 [000] … 937.839384: rtos_queue_send_from_isr_failed: tstamp:29709958528 queue:0x0bcb41f8
kworker/0:4-1751 [000] … 937.839385: rtos_queue_send_from_isr_failed: tstamp:29709958678 queue:0x0bcb8a60
kworker/0:4-1751 [000] … 937.839386: rtos_queue_send_from_isr_failed: tstamp:29709958830 queue:0x0bcba5e0
kworker/0:4-1751 [000] … 937.839387: rtos_queue_send_from_isr_failed: tstamp:29709958978 queue:0x0bcbb3a0
kworker/0:4-1751 [000] … 937.839388: rtos_queue_send_from_isr_failed: tstamp:29709959141 queue:0x0bcbc160
kworker/0:4-1751 [000] … 937.839391: rtcpu_string: tstamp:29709964885 id:0x04010000 str:"Configuring VI GoS.
kworker/0:4-1751 [000] … 937.839411: rtcpu_string: tstamp:29709965067 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:4-1751 [000] … 937.839446: rtcpu_string: tstamp:29709965319 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:4-1751 [000] … 937.839452: rtcpu_string: tstamp:29709965583 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:4-1751 [000] … 937.839459: rtcpu_string: tstamp:29709965814 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:4-1751 [000] … 937.839466: rtcpu_string: tstamp:29709966046 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:4-1751 [000] … 937.839472: rtcpu_string: tstamp:29709966277 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:4-1751 [000] … 937.839479: rtos_queue_send_from_isr_failed: tstamp:29709966633 queue:0x0bcb41f8
kworker/0:4-1751 [000] … 937.839480: rtos_queue_send_from_isr_failed: tstamp:29709966793 queue:0x0bcb8a60
kworker/0:4-1751 [000] … 937.839481: rtos_queue_send_from_isr_failed: tstamp:29709966951 queue:0x0bcba5e0
kworker/0:4-1751 [000] … 937.839482: rtos_queue_send_from_isr_failed: tstamp:29709967104 queue:0x0bcbb3a0
kworker/0:4-1751 [000] … 937.839484: rtos_queue_send_from_isr_failed: tstamp:29709967253 queue:0x0bcbc160
kworker/0:4-1751 [000] … 937.839485: rtos_queue_send_from_isr_failed: tstamp:29709971241 queue:0x0bcb41f8
kworker/0:4-1751 [000] … 937.839486: rtos_queue_send_from_isr_failed: tstamp:29709971390 queue:0x0bcb8a60
kworker/0:4-1751 [000] … 937.839487: rtos_queue_send_from_isr_failed: tstamp:29709971541 queue:0x0bcba5e0
kworker/0:4-1751 [000] … 937.839489: rtos_queue_send_from_isr_failed: tstamp:29709971689 queue:0x0bcbb3a0
kworker/0:4-1751 [000] … 937.839490: rtos_queue_send_from_isr_failed: tstamp:29709971834 queue:0x0bcbc160
kworker/0:4-1751 [000] … 937.839492: rtcpu_vinotify_event: tstamp:29710410370 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:31596252800 data:0x10000000
kworker/0:4-1751 [000] … 937.839494: rtcpu_vinotify_event: tstamp:29710410540 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:31596282176 data:0x31000001
kworker/0:4-1751 [000] … 937.839495: rtcpu_vinotify_event: tstamp:29710410680 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:31596292352 data:0x10000000
kworker/0:4-1751 [000] … 937.839523: rtcpu_vinotify_event: tstamp:29710410839 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:31596300800 data:0x07020001
kworker/0:4-1751 [000] … 937.839524: rtcpu_vinotify_event: tstamp:29710410976 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:31596331264 data:0x31000002
kworker/0:4-1751 [000] … 938.007426: rtos_queue_peek_from_isr_failed: tstamp:29714630671 queue:0x0bcbcf78
kworker/0:4-1751 [000] … 938.119371: rtos_queue_peek_from_isr_failed: tstamp:29719630671 queue:0x0bcbcf78
vi-output, imx2-8864 [001] … 938.267109: tegra_channel_capture_frame: sof:951.175757728
vi-output, imx2-8864 [001] … 938.267115: tegra_channel_capture_frame: eof:951.175914976
vi-output, imx2-8864 [001] … 938.267132: tegra_channel_capture_frame: sof:951.175916256
vi-output, imx2-8864 [001] … 938.267134: tegra_channel_capture_frame: eof:951.176073504
kworker/0:4-1751 [000] … 938.287378: rtcpu_vinotify_event: tstamp:29724260230 tag:FS channel:0x00 frame:0 vi_tstamp:29724242401 data:0x00000010
kworker/0:4-1751 [000] … 938.287384: rtcpu_vinotify_event: tstamp:29724260382 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:29724242404 data:0x00000000
kworker/0:4-1751 [000] … 938.287385: rtcpu_vinotify_event: tstamp:29724260548 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:29724242429 data:0x00000001
kworker/0:4-1751 [000] … 938.287386: rtcpu_vinotify_event: tstamp:29724260687 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:27757806912 data:0x08020001
kworker/0:4-1751 [000] … 938.287387: rtcpu_vinotify_event: tstamp:29724260845 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:29724247305 data:0x00000002
kworker/0:4-1751 [000] … 938.287388: rtcpu_vinotify_event: tstamp:29724260981 tag:FE channel:0x00 frame:0 vi_tstamp:29724247328 data:0x00000020
kworker/0:4-1751 [000] … 938.287391: rtcpu_vinotify_event: tstamp:29724261159 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:29724247331 data:0x00000000
kworker/0:4-1751 [000] … 938.287392: rtcpu_vinotify_event: tstamp:29724261294 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:29724247343 data:0x00000000
kworker/0:4-1751 [000] … 938.287393: rtcpu_vinotify_event: tstamp:29724261452 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:27757972160 data:0x02020001
kworker/0:4-1751 [000] … 938.287394: rtcpu_vinotify_event: tstamp:29724261585 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:27757984736 data:0x00020001
kworker/0:4-1751 [000] … 938.287395: rtcpu_vinotify_event: tstamp:29724261744 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:27758007040 data:0x07020002
kworker/0:4-1751 [000] … 938.287396: rtcpu_vinotify_event: tstamp:29724261880 tag:FS channel:0x00 frame:0 vi_tstamp:29724247356 data:0x00000010
kworker/0:4-1751 [000] … 938.287397: rtcpu_vinotify_event: tstamp:29724262037 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:29724247358 data:0x00000000
kworker/0:4-1751 [000] … 938.287398: rtcpu_vinotify_event: tstamp:29724262172 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:29724247383 data:0x00000001
kworker/0:4-1751 [000] … 938.287400: rtcpu_vinotify_event: tstamp:29724262330 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:27758026240 data:0x08020002
kworker/0:4-1751 [000] … 938.287401: rtcpu_vinotify_event: tstamp:29724262463 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:29724252260 data:0x00000002
kworker/0:4-1751 [000] … 938.287402: rtcpu_vinotify_event: tstamp:29724262619 tag:FE channel:0x00 frame:0 vi_tstamp:29724252283 data:0x00000020
kworker/0:4-1751 [000] … 938.287403: rtcpu_vinotify_event: tstamp:29724262759 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:29724252286 data:0x00000000
kworker/0:4-1751 [000] … 938.287404: rtcpu_vinotify_event: tstamp:29724262917 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:29724252297 data:0x00000000
kworker/0:4-1751 [000] … 938.287405: rtcpu_vinotify_event: tstamp:29724263052 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:27758129920 data:0x02020002
kworker/0:4-1751 [000] … 938.287406: rtcpu_vinotify_event: tstamp:29724263208 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:27758144992 data:0x00020002
kworker/0:4-1751 [000] … 938.287407: rtcpu_vinotify_event: tstamp:29724263342 tag:FS channel:0x00 frame:0 vi_tstamp:29724252310 data:0x00000010
kworker/0:4-1751 [000] … 938.287411: rtcpu_vinotify_error: tstamp:29724266758 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:29724252338 data:0x00000549
kworker/0:4-1751 [000] … 938.287412: rtcpu_vinotify_error: tstamp:29724267749 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:29724257292 data:0x00000549
kworker/0:4-1751 [000] … 938.287413: rtcpu_vinotify_error: tstamp:29724268411 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:29724262247 data:0x00000549
kworker/0:4-1751 [000] … 938.287414: rtcpu_vinotify_error: tstamp:29724271458 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:29724267201 data:0x00000549
kworker/0:4-1751 [000] … 938.287415: rtcpu_vinotify_error: tstamp:29724276278 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:29724272156 data:0x00000549
kworker/0:4-1751 [000] … 938.287416: rtcpu_vinotify_error: tstamp:29724280153 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:29724277111 data:0x00000549
kworker/0:4-1751 [000] … 938.287418: rtcpu_vinotify_event: tstamp:29724280614 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:29724252338 data:0x00000549
kworker/0:4-1751 [000] … 938.287419: rtcpu_vinotify_event: tstamp:29724280754 tag:FE channel:0x00 frame:0 vi_tstamp:29724257238 data:0x00000020
kworker/0:4-1751 [000] … 938.287420: rtcpu_vinotify_event: tstamp:29724280911 tag:FS channel:0x00 frame:0 vi_tstamp:29724257265 data:0x00000010
kworker/0:4-1751 [000] … 938.287421: rtcpu_vinotify_event: tstamp:29724281047 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:29724257292 data:0x00000549
kworker/0:4-1751 [000] … 938.287422: rtcpu_vinotify_event: tstamp:29724281203 tag:FE channel:0x00 frame:0 vi_tstamp:29724262192 data:0x00000020
kworker/0:4-1751 [000] … 938.287423: rtcpu_vinotify_event: tstamp:29724281338 tag:FS channel:0x00 frame:0 vi_tstamp:29724262219 data:0x00000010
kworker/0:4-1751 [000] … 938.287424: rtcpu_vinotify_event: tstamp:29724281493 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:29724262247 data:0x00000549
kworker/0:4-1751 [000] … 938.287425: rtcpu_vinotify_event: tstamp:29724281628 tag:FE channel:0x00 frame:0 vi_tstamp:29724267147 data:0x00000020
kworker/0:4-1751 [000] … 938.287426: rtcpu_vinotify_event: tstamp:29724281785 tag:FS channel:0x00 frame:0 vi_tstamp:29724267173 data:0x00000010
kworker/0:4-1751 [000] … 938.287428: rtcpu_vinotify_event: tstamp:29724281920 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:29724267201 data:0x00000549
kworker/0:4-1751 [000] … 938.287429: rtcpu_vinotify_event: tstamp:29724282074 tag:FE channel:0x00 frame:0 vi_tstamp:29724272101 data:0x00000020
kworker/0:4-1751 [000] … 938.287430: rtcpu_vinotify_event: tstamp:29724282209 tag:FS channel:0x00 frame:0 vi_tstamp:29724272129 data:0x00000010
kworker/0:4-1751 [000] … 938.287431: rtcpu_vinotify_event: tstamp:29724282365 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:29724272156 data:0x00000549
kworker/0:4-1751 [000] … 938.287432: rtcpu_vinotify_event: tstamp:29724282498 tag:FE channel:0x00 frame:0 vi_tstamp:29724277055 data:0x00000020
kworker/0:4-1751 [000] … 938.287433: rtcpu_vinotify_event: tstamp:29724282653 tag:FS channel:0x00 frame:0 vi_tstamp:29724277082 data:0x00000010
kworker/0:4-1751 [000] … 938.287434: rtcpu_vinotify_event: tstamp:29724282787 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:29724277111 data:0x00000549
kworker/0:4-1751 [000] … 938.287437: rtos_queue_send_from_isr_failed: tstamp:29724310811 queue:0x0bcb41f8
kworker/0:4-1751 [000] … 938.287439: rtos_queue_send_from_isr_failed: tstamp:29724310967 queue:0x0bcb8a60
kworker/0:4-1751 [000] … 938.287451: rtos_queue_send_from_isr_failed: tstamp:29724311117 queue:0x0bcba5e0
kworker/0:4-1751 [000] … 938.287453: rtos_queue_send_from_isr_failed: tstamp:29724311265 queue:0x0bcbb3a0
Could you please give some idea
One more doubt that, I saw CHANSEL_NOMATCH channel:0x01 in trace log, is this mean that sensor sending channel 1 data.
nomatch log shows VI received pixels with dataType=RAW8 (bit[10:5] on data field: 0x00000549), and no channel to match this, please confirm if RAW8 is expected input format, and if a VI channel has been programmed to catch that
Hi ShaneCC,
Thanks for your support , Yes RAW8 is the expected Input. Could you please suggest any Idea. I see LS(Line Start) in CTYPE bit[4:1] is enabled in data field: 0x00000549 what it’s showing , This LS is coming from long packet or short packet.
if RAW8 is expected format, may need to confirm VI channel has been programmed correct to catch that.
