Hi NV,
How to use both Xavier A and B and visualize on the same video window?
E.g., Xavier A activates DriveNet and Xavier B activates LaneNet. Render both of their detected objects and lanes on the same video streaming.
Hi NV,
Dear songwen.huang,
It seems to be the case to run different applications in XaiverA / B.
I think even if you run the commands that run each application at the same time, you will not see what you want at the same time because the loading time is different.
I’d like to suggest that you use the roadrunner sample or integrate the two codes to make it separate. Thanks.
