I want to use watchdog functionality of ORIN AGX series module but don’t know exact details about this pin.
please let me is it separate watchdog timer in module which is driving this pin?
Or
do i need to connect external watchdog timer on this pin so that it can send the reset if module will enter in hang state?
Please suggest me topology to trigger reset if ORIN SOM is in Hung state?
I am using ORIN AGX. I am in design phase so just want to know do we need to external watchdog timer if my ORIN AGX SOM will get hanged or SOM already taken care internally?
yes you are correct watchdog is timer, it will count time(or ticks) but i dont if i will use exteral watchdog timer then how it count ORIN AGX SOM time.
From design purpose where we need to connect external watchdog timer on ORIN AGX SOM?
I have one more doubt as per AGX ORIN design guide this pin in bidirectional. So just want to what is the purpose of this pin if i configured this pin as Input?
It depends on your connection and usage.
I’ve checked this with internal that WDT_RESET_OUT_N is not supported for AGX Orin yet, but the watchdog feature should still work.
as of now i planned to use it in O/P mode to monitor the watchdog timeout happen or not. If happen, trigger the SYS_RST so that ORIN Module restart the booting.
