Hi, I’m using cuda-memcheck to debug my deepstream app, which have memory leak problem. The output shows like that. But I donnot understand what it means? After google, I can’t find any explaination about trt_volta_fp32_icudnn_int8x4_128x64_relu_small_nn_v1 ? Can anyone help me with that?
Creating LL OSD context new
========= Internal Memcheck Error: Detected racecheck error buffer overflow. Some records have been dropped.
========= Saved host backtrace up to driver entry point at error
========= Host Frame:/usr/lib/x86_64-linux-gnu/libcuda.so.1 [0x22b118]
========= Host Frame:/lib/x86_64-linux-gnu/libpthread.so.0 [0x76db]
========= Host Frame:/lib/x86_64-linux-gnu/libc.so.6 (clone + 0x3f) [0x12188f]
========= WARN: Race reported between Read access at 0x00005fa0 in trt_volta_fp32_icudnn_int8x4_128x64_relu_small_nn_v1
========= and Write access at 0x00005f30 in trt_volta_fp32_icudnn_int8x4_128x64_relu_small_nn_v1 [252816 hazards]
========= WARN: Race reported between Read access at 0x00005fc0 in trt_volta_fp32_icudnn_int8x4_128x64_relu_small_nn_v1
========= and Write access at 0x00005f30 in trt_volta_fp32_icudnn_int8x4_128x64_relu_small_nn_v1 [252752 hazards]
========= WARN: Race reported between Read access at 0x00005f60 in trt_volta_fp32_icudnn_int8x4_128x64_relu_small_nn_v1
========= and Write access at 0x00005f30 in trt_volta_fp32_icudnn_int8x4_128x64_relu_small_nn_v1 [253784 hazards]
========= WARN: Race reported between Read access at 0x00005f80 in trt_volta_fp32_icudnn_int8x4_128x64_relu_small_nn_v1
========= and Write access at 0x00005f30 in trt_volta_fp32_icudnn_int8x4_128x64_relu_small_nn_v1 [253084 hazards]
========= WARN: Race reported between Read access at 0x00005fb0 in trt_volta_fp32_icudnn_int8x4_128x64_relu_small_nn_v1
========= and Write access at 0x00005f40 in trt_volta_fp32_icudnn_int8x4_128x64_relu_small_nn_v1 [230274 hazards]
========= WARN: Race reported between Read access at 0x00005fd0 in trt_volta_fp32_icudnn_int8x4_128x64_relu_small_nn_v1
========= and Write access at 0x00005f40 in trt_volta_fp32_icudnn_int8x4_128x64_relu_small_nn_v1 [230213 hazards]
========= WARN: Race reported between Read access at 0x00005f70 in trt_volta_fp32_icudnn_int8x4_128x64_relu_small_nn_v1
========= and Write access at 0x00005f40 in trt_volta_fp32_icudnn_int8x4_128x64_relu_small_nn_v1 [231060 hazards]
========= WARN: Race reported between Read access at 0x00005f90 in trt_volta_fp32_icudnn_int8x4_128x64_relu_small_nn_v1
========= and Write access at 0x00005f40 in trt_volta_fp32_icudnn_int8x4_128x64_relu_small_nn_v1 [230543 hazards]
========= Error: process didn’t terminate successfully
========= The application may have hit an error when dereferencing Unified Memory from the host. Please rerun the application under cuda-gdb or Nsight Eclipse Edition to catch host side errors.
