Use customized rootfs in JetPack Cross Compilation container
According to this doc, I cloned the rootfs from the Jetson Orin AGX device.
sudo ./flash.sh -r -k APP -G rootfs.img jetson-agx-orin-devkit mmcblk0p1
Then, I copied rootfs.img.raw to JetPack Cross Compilation container. And mount this rootfs.
mkdir /rootfs
mount -t ext4 rootfs.img.raw /rootfs
However, the symbolic links in /rootfs are broken.
Is there a good way to solve these broken symbolic links?
Is this a duplicate of the topic below?
If so, would you mind sharing your use case so we can provide a more accurate suggestion/recommendation?
@AastaLLL I’ve shared the use case in this topic. And this topic can be set as duplicated.
