Use detectnet to track two objects with same ClassID
I can use detectnet to get the ClassID, x/y coordinate… However, if there are two objects with same ClassID, can I distinguish the two objects? I need to track the object using the x,y coordinate. Then, use the coordinates and fps to estimate the speed. (assume in horizontal direction)
Thanks,
You will need a tracking algorithm for bounding boxes from the adjacency frames.
There are several frameworks can do this.
For example, you can apply the tracker algorithm from VPI or OpenCV.
https://docs.nvidia.com/vpi/algo_klt_tracker.html
Or you can use Deepstream SDK which can support inference + tracking directly.
Mmm… thx. It is getting complicated… I was hoping if detectNet has ItemID for each item…
I may make a range of previous xy coordinates, if the new xy coordinates are within the range, I assume it is the same object then.
Thanks,
For simplicity, you can do it by checking the bbox location directly.
But please noted that you may still need a tracker if the bbox occlusion is possible.
Is it possible to use SORT or DeepSORT with the jetson-inference? Is there any example?
I saw people use SORT with Yolo only… Thx
