"Use Fast Math" property seems no effect for ptx generation
Since some recent version of CUDA, Visual Studio integration provides “Use Fast Math” property (CUDA C/C++ > Device > Use Fast Math) but this seems no effect for ptx generation (NVCC Compilation Type == Generate device-only .ptx file (-ptx)).
I tested with CUDA file like:
#include <cstdio>
#include <cstdint>
extern "C" __global__ void test(float* values) {
    uint32_t globalIdx = blockDim.x * blockIdx.x + threadIdx.x;
    values[globalIdx] = std::sin(values[globalIdx]);
Generated ptx file doesn’t contain sin.approx.ftz.f32 instruction even if I set “Use Fast Math” property to true. When I manually specify “–use_fast_math” from the additional options for command line, it contains.
CUDA 11.1
Visual Studio Community 2019 16.7.6
  1. I wouldn’t recommend using std::sin. nvcc doesn’t officially support the use of std library in device code. Programming Guide :: CUDA Toolkit Documentation
  2. According to the programming guide, the function conversion applies to sinf(), not sin(): Programming Guide :: CUDA Toolkit Documentation
You may wish to file a bug for your observation.
I filed a bug and the development team is looking at it.
Thanks for filing the bug. I hope this will be fixed.
Regarding to std::sin, indeed I have been wondering why I can use such functions in std even without including the header and I could not have found mentions about them in the official CUDA documentations. I have been using them because they are abstract to float or double therefore feel useful.
