Use gpio from l4t-ml container
First, on the TX2 body
sudo apt install python3-dev python3-pip
cd /opt/nvidia/
sudo git clone https://github.com/NVIDIA/jetson-gpio.git
cd jetson-gpio
sudo python3 setup.py install
cd /opt/nvidia/jetson-gpio/samples
python3 simple_out.py
is working
However
After executing -v /sys:/sys -v /usr:/usr -v /proc:/proc -v /opt:/opt when executing the l4t-ml container
not working
The error is
No such file or directory: ‘/proc/device-tree/compatible’
In TX2 itself, you can see that /proc/device-tree is linked to /sys/firmware/devicetree/base, but /sys/firmware/devicetree/base does not exist in the l4t-ml container
-v /sys:/sys I wonder if everything is mounted, but it doesn’t seem to be.
How can I mount all of/sys?
hello yoshifumi_watanabe_aa,
Jetson GPIO is a python library that enables the use of Jetson’s GPIOs, it may not supports while you’re using a container.
could you please access those GPIOs through system nodes, please refer to TX2 J21 Header Pinout for GPIO numbers.
you may enable GPIOs manually for usage.
for example,
$ echo 220 > /sys/class/gpio/export
$ echo out > /sys/class/gpio/gpio220/direction
$ echo 1 > /sys/class/gpio/gpio220/value
When 220 was changed to 255, 3V output could be confirmed. However, I want to be able to execute it on a python program like simple_out.py. Is it possible to mount all / sys somehow?
このリンク先にある投稿を参考にさせてもらいました
using GPIO from within a docker container
sudo pip3 install git + https: //github.com/Heerpa/jetson-gpio
cd /usr/local/lib/python3.6/dist-packages/jetson/GPIO
sudo chmod 777 gpio_pin_data.py
In def get_data(): change the model to JETSON_TX2
sudo chmod 777 simple_out.py
Change 1 second to 5 seconds (because I want to see it on the tester)
sudo docker run ・・・-v /etc/udev/rules.d:/etc/udev/rules.d -v /sys/class/gpio:/sys/class/gpio -v /sys/devices:/sys/devices -v /dev/gpiochip0:/dev/gpiochip0 -v /dev/gpiochip1:/dev/gpiochip1 -v /opt:/opt ・・・Container name
Voltage between 12 and 14 ON/OFF 3.3V was confirmed
