I want to use the nx for an embedded solution without the Desktop/GUI. The plan is to show a “live-view” on a HDMI Monitor. I need a “fast” booting solution and can’t wait for Gnome to start. Im using opencv with gstreamer and python or c.
Also I don’t want to have a gui for security reasons
Any Ideas ? Best regards Martin
thank you for this solution, works pretty nice:
gst-launch-1.0 filesrc location=1.mp4 ! qtdemux name=demux ! h264parse ! nvv4l2decoder ! nvdrmvideosink -e
with python3 /opencv i got: GStreamer warning: error opening writer pipeline: syntax error
ret, frame_read = cap.read()
frame_height, frame_width, _ = frame_read.shape
gst_str = "appsrc ! videoconvert ! qtdemux name=demux ! h264parse ! nvv4l2decoder ! nvdrmvideosink -e "
stream = cv2.VideoWriter(gst_str, 0, 25, (frame_width, frame_height), True)
while True:
stream.write(frame_read)
any ideas how to improve my pipeline ?
okay this pipeline works so far, im happy with it !
gst_str = "appsrc ! videoconvert ! nvvidconv ! video/x-raw(memory:NVMM),width=1920,height=1080,format=RGBA !
nvdrmvideosink sync=false "
But if there any ideas how to improve this pipeline, i would be happy for some input
Best regards Martin
There is BGR to RGBA conversion in videoconvert plugin, and copying data from CPU buffer to MVMM buffer in nvvidconv plugin. These utilize CPU usage so suggest execute sudo nvpmodel -m 2
and sudo tegrastats
, to enable 6 CPU cores at 1.4GHz.
