Run OpenPose on NX.
I found that GPU usage reached 100%.
Memory left 777M, CPU left 77%.
May I ask, may this problem be caused by the high use of GPU?
Run OpenPose on NX.
It’s possible.
Which openpose source do you use?
We have tried to run openpose with our Deepstream library.
And doesn’t see any screen stuck issue.
Thanks for you reply.
We use the original openpouse(caffe).
Thank you for your recommendation. I’ll have a try
