Use intel Realsense t265 with GStremer Jatson
Hello All,
I have of course a Jatson Xavier NX and a intel T265 Realsense camera ,
my goal is to get raw video fata from that camera → encoding it with gstreamer → write encoded data in a ros topic → acces that data from a remote server.
To to this i installed :
  • LibRealSense SDK Backend following the documentation here chosing " Building from Source using Native Backend". This step seems work fine.
  • gstreamer-python, using the “in-place” procedure. This too seems to work as expected.
Than i tried to combine all this in the following script:
basically i want to build a gst pipeline with custom input (the data coming from the camera (appsrc source)) and encoding it to a file (just for initial test purpose)
# First import the library
import gstreamer
from gstreamer import GstContext, GstPipeline, GstApp, Gst, GstVideo, GLib, GstVideoSink
import gstreamer.utils as utils
import pyrealsense2 as rs
import numpy as np
from fractions import Fraction
import sys
import traceback
import argparse
import typing as typ
import random
import time
# Declare RealSense pipeline, encapsulating the actual device and sensors
pipe = rs.pipeline()
# Build config object and request pose data
cfg = rs.config()
cfg.enable_stream(rs.stream.fisheye)
cfg.enable_all_streams()
# Start streaming with requested config
pipe.start(cfg)
VIDEO_FORMAT = "GRAY8"
WIDTH, HEIGHT = 848, 800
FPS = Fraction(30)
GST_VIDEO_FORMAT = GstVideo.VideoFormat.from_string(VIDEO_FORMAT)
def fraction_to_str(fraction: Fraction) -> str:
    """Converts fraction to str"""
    return '{}/{}'.format(fraction.numerator, fraction.denominator)
def parse_caps(pipeline: str) -> dict:
    """Parses appsrc's caps from pipeline string into a dict
    :param pipeline: "appsrc caps=video/x-raw,format=RGB,width=640,height=480 ! videoconvert ! autovideosink"
    Result Example:
            "width": "640",
            "height": "480"
            "format": "RGB",
            "fps": "30/1",
    try:
        # typ.List[typ.Tuple[str, str]]
        caps = [prop for prop in pipeline.split(
            "!")[0].split(" ") if "caps" in prop][0]
        return dict([p.split('=') for p in caps.split(',') if "=" in p])
    except IndexError as err:
        return None
FPS_STR = fraction_to_str(FPS)
DEFAULT_CAPS = "video/x-raw,format={VIDEO_FORMAT},width={WIDTH},height={HEIGHT},framerate={FPS_STR}".format(**locals())
# Converts list of plugins to gst-launch string
# ['plugin_1', 'plugin_2', 'plugin_3'] => plugin_1 ! plugin_2 ! plugin_3
DEFAULT_PIPELINE = utils.to_gst_string([
    "appsrc emit-signals=True is-live=True caps={DEFAULT_CAPS}".format(**locals()),
    "omxh264enc",
    "video/x-h264, stream-format=byte-stream",
    "h264parse",
    "qtmux",
    "filesink location=test.mp4 -e"
ap = argparse.ArgumentParser()
ap.add_argument("-p", "--pipeline", required=False,
                default=DEFAULT_PIPELINE, help="Gstreamer pipeline without gst-launch")
ap.add_argument("-n", "--num_buffers", required=False,
                default=100, help="Num buffers to pass")
args = vars(ap.parse_args())
command = args["pipeline"]
args_caps = parse_caps(command)
NUM_BUFFERS = int(args['num_buffers'])
WIDTH = int(args_caps.get("width", WIDTH))
HEIGHT = int(args_caps.get("height", HEIGHT))
FPS = Fraction(args_caps.get("framerate", FPS))
    args_caps.get("format", VIDEO_FORMAT))
CHANNELS = utils.get_num_channels(GST_VIDEO_FORMAT)
DTYPE = utils.get_np_dtype(GST_VIDEO_FORMAT)
with GstContext():  # create GstContext (hides MainLoop)
    pipeline = GstPipeline(command)
    def on_pipeline_init(self):
        """Setup AppSrc element"""
        appsrc = self.get_by_cls(GstApp.AppSrc)[0]  # get AppSrc
        # instructs appsrc that we will be dealing with timed buffer
        appsrc.set_property("format", Gst.Format.TIME)
        # instructs appsrc to block pushing buffers until ones in queue are preprocessed
        # allows to avoid huge queue internal queue size in appsrc
        appsrc.set_property("block", True)
        # set input format (caps)
        appsrc.set_caps(Gst.Caps.from_string(CAPS))
    # override on_pipeline_init to set specific properties before launching pipeline
    pipeline._on_pipeline_init = on_pipeline_init.__get__(pipeline)
    try:
        pipeline.startup()
        appsrc = pipeline.get_by_cls(GstApp.AppSrc)[0]  # GstApp.AppSrc
        pts = 0  # buffers presentation timestamp
        duration = 10**9 / (FPS.numerator / FPS.denominator)  # frame duration
        for _ in range(NUM_BUFFERS):
            frames = pipe.wait_for_frames()
            fisheye1 = frames.get_fisheye_frame(1).as_video_frame().get_data()
            array = np.asanyarray(fisheye1)
            # convert np.ndarray to Gst.Buffer
            gst_buffer = utils.ndarray_to_gst_buffer(array)
            # set pts and duration to be able to record video, calculate fps
            pts += duration  # Increase pts by duration
            gst_buffer.pts = pts
            gst_buffer.duration = duration
            # emit <push-buffer> event with Gst.Buffer
            appsrc.emit("push-buffer", gst_buffer)
        # emit <end-of-stream> event
        appsrc.emit("end-of-stream")
        while not pipeline.is_done:
            time.sleep(.1)
    except Exception as e:
        print("Error: ", e)
    finally:
        pipe.stop()
        pipeline.shutdown()
I tried a lot of gst_pipeline combination, ma no one work for me, always i get a syntax error:
>>> exec(open('/home/valiokei/Gstreamer/venv/gstreamer-python/examples/Test2.py').read())
Error:  gst_parse_error: syntax error (0)
Can anyone guide me to work it out?
Hello, thank you for the post.
I will notify the developers of your issue.
Thank you for your patience.
After reviewing your issue it does not seem to be related to Omniverse.
Please use the following link to re-post to our Jetson specific topic area.
Thank you.
