use macro to define function name in Fortran
Is it possible to use macro to define function name in the Fortran source code like in C, so that I can easily switch to the version of code I want to use
Say I call to func_1 at multiple locations. Now I have another implementation of func_1, called func_2. I want to test/compare between func_1 and func_2.
In C, I just use func_ at every location I call, and in the begining of the file, I just define
#define func_ func_1
! or
#define func_ func_2
Can we do this in Fortran?
Thanks,
Tuan
Hi Tuan,
Sure. You can use most C pre-processing statements by using the “-Mpreprocess” flag or have upper case suffix names (i.e. .F or .F90). Pre-processing is on by default when the suffix is upper case.
Alternatively, you can use the “-Mcpp” flag to use the cpp preprocessor instead of the internal Fortran pre-processor.
Hope this helps,
Mat
