I’m having some issues trying to flash a Xavier NX that has JP4.6 installed to JP5.1.1, using massflash. With this, I’m able to flash the NX with JP4.6 installed, boots ok and I can use the cameras:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh \ --external-device nvme0n1 -c ./tools/kernel_flash/flash_l4t_nvme.xml \ --no-flash -S 200GiB \ --showlogs jetson-xavier-nx-devkit-emmc nvme0n1p1 sudo ./tools/kernel_flash/l4t_initrd_flash.sh \ --external-device nvme0n1 -c ./tools/kernel_flash/flash_l4t_nvme.xml \ --showlogs --flash-only -S 200GiB \ jetson-xavier-nx-devkit-emmc nvme0n1p1
But when I add the massflash flag and use it, it throws error flashing qspi. After that it boots but there is something wrong on the kernel logs, and after I try to use a camera the capture crashes and the device gets dropped.
Here are the full kernel logs, I also I’m attaching one from a healthy NX with JP5.
kernellog_normal.log (68.9 KB)
kernellog_bad.log (96.0 KB)
Note the initial part on the kernellog_bad.log:
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x4e0f0040] [ 0.000000] Linux version 5.10.104-tegra (root@aartavia-Satellite-S55-B) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #2 SMP PREEMPT Tue Aug 8 08:56:42 CST 2023 [ 0.000000] OF: fdt: memory scan node memory, reg size 48, [ 0.000000] OF: fdt: - 80000000 , 2c000000 [ 0.000000] OF: fdt: - ac200000 , 44800000 [ 0.000000] OF: fdt: - 100000000 , 180000000 [ 0.000000] Machine model: NVIDIA Jetson Xavier NX Developer Kit [ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '') [ 0.000000] printk: bootconsole [tegra_comb_uart0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB [ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB [ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB [ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB [ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB [ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB [ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB [ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x000000027fffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x00000000abffffff] [ 0.000000] node 0: [mem 0x00000000ac200000-0x00000000f07fffff] [ 0.000000] node 0: [mem 0x0000000100000000-0x000000027fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000027fffffff] [ 0.000000] On node 0 totalpages: 2033152 [ 0.000000] DMA zone: 7192 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 460288 pages, LIFO batch:63 [ 0.000000] Normal zone: 24576 pages used for memmap [ 0.000000] Normal zone: 1572864 pages, LIFO batch:63 [ 0.000000] cma: Reserved 64 MiB at 0x00000000ec800000
There is the efi: UEFI not found. and also the memory ranges are way different.
I also added:
-p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg"
But I get the same results.
Regards,
Andres
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.c om/
Website: www.ridgerun.com
