Use nvdewarper plugin together with regular video source in single pipeline
GPU - RTX2060
• DeepStream Version
5.1
n/a
• TensorRT Version
7.2.3-1+cuda11.1
455.32.00
question
n/a
I’m trying to use the nvdewarper plugin together with a regular video source. I modified the config file loader so that a dewarper config can be attached to each source element via NvDsSourceConfig::dewarper_config (deepstream_sources.h:77).
The config for the sources is:
[source0]
enable=1
type=3
uri=file:///home/videos/FISHEYE.mp4
gpu-id=0
nvbuf-memory-type=0
dewarper-enable=1
dewarper-config-file=dewarping_config.ini
dewarper-num-surfaces-per-frame=2
dewarper-source-id=0
[source1]
enable=1
type=3
uri=file:///home/videos/REGULAR.mp4
gpu-id=0
nvbuf-memory-type=0
This works well only one of the sources is enabled. However, if using both sources, the application fails with an error from nvstreammux:
ERROR from src_bin_muxer: Input buffer number of surfaces (1) must be equal to mux->num_surfaces_per_frame (2)
Set nvstreammux property num-surfaces-per-frame appropriately
The main source file used is the modified example app from deepstream-occupancy-analytics
Here, I set the num-surfaces-per-frame to equal the number of dewarp surfaces from the source group.
g_object_set (appCtx[i]->pipeline.multi_src_bin.streammux,
“buffer-pool-size”, STREAMMUX_BUFFER_POOL_SIZE,
“num-surfaces-per-frame”, 2,
NULL);
To sum it up, is it possible to use dewarped video sources together with regular video sources in the same pipeline? If so, how to set up the streammux to be able to handle both type of sources (with one or multiple surfaces per frame).
Does regular source mean one frame only includes one surface?
Yes, a source that does not use the dewarper plugin has only one surface, according to the error message given by streammux.
Ok, can you share your pipeline what you are trying to do?
