I will first summarize what I think I understood about cuDNN 5.1 rnn functions:
x = [seq_length, batch_size, vocab_size] # input
y = [seq_length, batch_size, hiddenSize] # output
dx = [seq_length, batch_size, vocab_size] # input gradient
dy = [seq_length, batch_size, hiddenSize] # output gradient
hx = [num_layer, batch_size, hiddenSize] # input hidden state
hy = [num_layer, batch_size, hiddenSize] # output hidden state
cx = [num_layer, batch_size, hiddenSize] # input cell state
cy = [num_layer, batch_size, hiddenSize] # output cell state
dhx = [num_layer, batch_size, hiddenSize] # input hidden state gradient
dhy = [num_layer, batch_size, hiddenSize] # output hidden state gradient
dcx = [num_layer, batch_size, hiddenSize] # input cell state gradient
dcy = [num_layer, batch_size, hiddenSize] # output cell state gradient
w = [param size] # parameters (weights & bias)
dw = [param size] # parameters gradients
cudnnRNNForwardTraining/cudnnRNNForwardInference
input: x, hx, cx, w
output: y, hy, cy
cudnnRNNBackwardData
input: y, dy, dhy, dcy, w, hx, cx
output: dx, dhx, dcx
cudnnRNNBackwardWeights
input: x, hx, y, dw
output: dw
Questions:
- Is the following training workflow for multi-layer RNN (num_layer > 1) correct?
init hx,cx,dhy,dcy to NULL
init w: (weights:small random values, bias: 1)
forward
backward data
backward weights
update weights: w += dw
dw = 0
goto 4
- Do you confirm cuDNN already implements stacked rnn when num_layer > 1? (no need to call num_layer times forward/backward methods)
- Should I re-inject hidden state & cell state into the network at next batch?
- The output in lstm formulas is hy. Should I use hy as output or y?
I am experimenting on a toy data set (x = a sentence repeated a few times, trying to predict next letter), so far the loss never converges.
network: input->lstm->fully connected->softmax
batchSize = 1
sequenceLength = 3
hiddenSize = 20
numLayers = 2
vocabSize/inputSize = 255
