In a Fortran module (hereafter, MESH_TYPES), I am defining a rather complex structure for handling a mesh type variable, which is partly shown below:
TYPE mesh_structure
INTEGER(C_INT) :: nVert, nCell
REAL(C_DOUBLE) :: hAvg, hMax, hMin
TYPE(vertex), DIMENSION(:), ALLOCATABLE :: Vert
TYPE(cell), DIMENSION(:), ALLOCATABLE :: Cell
END TYPE mesh_structure
I then have the following routine that I need to copy in the device memory:
SUBROUTINE COMPUTE_LINEAR_TET_MAPPING_COEFFICIENTS(vertices, mapCoeff)
!$ACC ROUTINE SEQ
!---- Shared modules
USE MESH_TYPES
!---- I/O variables
INTEGER(C_INT), DIMENSION(:), INTENT(IN) :: vertices
REAL(C_DOUBLE), DIMENSION(:,:), ALLOCATABLE :: mapCoeff
!---- Local variables
REAL(C_DOUBLE), DIMENSION(3) :: v1, v2, v3, v4
!---- Testing for bad input
IF (ALLOCATED(mapCoeff)) DEALLOCATE(mapCoeff)
!---- Allocate and initialize
ALLOCATE(mapCoeff(3,4))
mapCoeff(:,:) = 0.0
v1(:) = Mesh%Vert(vertices(1))%coor(:)
v2(:) = Mesh%Vert(vertices(2))%coor(:)
v3(:) = Mesh%Vert(vertices(3))%coor(:)
v4(:) = Mesh%Vert(vertices(4))%coor(:)
!---- Compute coefficients
mapCoeff(:,1) = v1(:)
mapCoeff(:,2) = v2(:) - v1(:)
mapCoeff(:,3) = v3(:) - v1(:)
mapCoeff(:,4) = v4(:) - v1(:)
END SUBROUTINE COMPUTE_LINEAR_TET_MAPPING_COEFFICIENTS
In order to successfully compile this routine, I (apparently) need to insert a “DECLARE CREATE” pragma for the global variable “Mesh”, which I have done just after the declaration of this variable in module MESH_TYPES:
TYPE(mesh_structure) :: Mesh
!$ACC DECLARE CREATE(Mesh)
Now, I have a problem when linking a program that makes use of module MESH_TYPES.
[ 48%] Building Fortran object app/add_mesh_boundary/CMakeFiles/add_mesh_boundary.dir/add_mesh_boundary.f90.o
[ 48%] Linking Fortran executable …/…/bin/add_mesh_boundary
nvlink error : Undefined reference to ‘_mesh_types_16’ in ‘CMakeFiles/add_mesh_boundary.dir/add_mesh_boundary.f90.o’
pgacclnk: child process exit status 2: /home/lanteri/opt/pgi/linux86-64-llvm/19.10/bin/pgnvd
I suspect that this is due to the fact that I am using the DECLARE CREATE before having allocated the
allocatable components of the variable Mesh.
Could you please give me some hints for solving this problem?
Thanks a lot in advance!
