I want to use plymouth to add our animation when boot. I followed this link Using plymouth on tx2.. But it did not work.
My board and release information is below.
cat nv_tegra_release
R32 (release), REVISION: 6.1, GCID: 27863751, BOARD: t186ref, EABI: aarch64
plymouth.log (86.4 KB)
I remove all console in kernel command line, and from plymouth log, it created drm devices, and can see fb0 and fb1 are added. But I can’t see splash show on the screen.
I attached the plymouth log, and copied some logs below. They seems having issues.
4月 19 20:04:44 txkj-nx plymouthd[5311]: [ply-device-manager.c:814] create_devices_from_terminals:checking for consoles
4月 19 20:04:44 txkj-nx plymouthd[5311]: [ply-device-manager.c:592] add_consoles_from_file:opening /sys/class/tty/console/active
4月 19 20:04:44 txkj-nx plymouthd[5311]: [ply-device-manager.c:600] add_consoles_from_file:reading file
4月 19 20:04:44 txkj-nx plymouthd[5311]: [ply-device-manager.c:638] add_consoles_from_file:console /dev/tty1 found!
4月 19 20:04:44 txkj-nx plymouthd[5311]: [ply-device-manager.c:414] watch_for_udev_events:watching for udev graphics device add and remove events
4月 19 20:04:44 txkj-nx plymouthd[5311]: [ply-device-manager.c:315] create_devices_for_subsystem:creating objects for drm devices
4月 19 20:04:44 txkj-nx plymouthd[5311]: [main.c:2400] main:entering event loop
4月 19 20:04:44 txkj-nx plymouthd[5311]: [ply-device-manager.c:378] on_udev_event:got add event for device fb1
4月 19 20:04:44 txkj-nx plymouthd[5311]: [ply-device-manager.c:394] on_udev_event:ignoring since we only handle subsystem graphics devices after timeout
4月 19 20:04:44 txkj-nx plymouthd[5311]: [ply-device-manager.c:378] on_udev_event:got add event for device fb0
4月 19 20:04:44 txkj-nx plymouthd[5311]: [ply-boot-server.c:388] print_connection_process_identity:connection is from pid 5334 (/bin/plymouth show-splash) with parent pid 1 (/lib/systemd/systemd --switched-root --system --deserialize 39)
4月 19 20:04:44 txkj-nx plymouthd[5311]: [ply-boot-server.c:484] ply_boot_connection_on_request:got show splash request
4月 19 20:04:44 txkj-nx plymouthd[5311]: [main.c:896] plymouth_should_ignore_show_splash_calls:checking if plymouth should be running
4月 19 20:04:44 txkj-nx plymouthd[5311]: [main.c:998] on_show_splash:no displays available to show splash on, waiting…
