Use pyserial from inside inference docker
Hello all.
I am trying pass serial data to an arduino, via pyserial, from inside the inference docker but there isn’t any devices in ls dev/ttyusb ?
The pyserial part works outside the docker.
I am running it from inside the inference docker because opencv wont import into python if I try to from outside the docker. I have installed it for sure?
This all works fine on another linux machine, so I just want to pass the usb device to the docker on run ?
Any help would be awesome!
Which JetPack do you use?
OpenCV Python is pre-installed via JetPack by default.
To use pyserial inside the container, please check the below topic first:
If you are referring to the jetson-inference docker, try adding flags like --device /dev/ttyUSB0 after this line of the docker/run.sh script:
