i’m using a jetson xavier agx with Jetpack 4.3.
I generated an engine for tensorrt and uses the C++ API.
For inference of the engine i use the asynchronous method enqueue().
Is it possible to use a part of the inferenceresult in another stream before the inference completly finished?
Thanks in advance.
Hi @simon.eichhammer, I believe you can do this by recording a cudaEvent to stream A, and then asynchronously waiting on that cudaEvent from stream B. This could be the rough flow:
tensorrt enqueue() on stream A
cudaEventRecord() on stream A
cudaStreamWaitEvent() on stream B
enqueue CUDA kernels on stream B
Here are the relevant APIs:
